Recommended Transmission shop
Old 06-09-2008, 01:07 AM
ls12000's Avatar
Default Recommended Transmission shop
Can anyone recommend a Good honest transmission shop in houston for my 00 T/A A4 tranmission. Ive been taking it AAMCO and everytime i take it there when i leave something else goes wrong with it. This last time they said that neck on my Yank 3200 stall was messed up causing it to leak trans fluid after they replaced all the seals. All i want is a good transmission shop that can fix it without having to go back every other day spending more money.
Old 06-09-2008, 01:43 AM
Skeet Skeet's Avatar
To bad your not in the tampa area because we have one of the best trannys guys around. transmision physician is the name maybe he knows somebody over there that he could refer you to. The guys name is fernando hope this can help you
Old 06-09-2008, 01:50 AM
NorCalLt4's Avatar
Look up rpm transmissions online. They are a bit pricey but way worth it though. I used to burn up my tranny all the time but this trans has taken everything and anything i can throw at it. They have all kinds of applications if you dont want to spend as much as i did. I bought the stage 5 which is approx about 3k but they have lower stages too. Their trannies are BAD ***!!!
Old 06-09-2008, 07:13 AM
Circle-D's Avatar
We are in Houston!!
Give me a call or PM and I will answer any questions you have.
Chris
Old 06-09-2008, 07:28 AM
TXZ28LS1's Avatar
Originally Posted by Circle-D
We are in Houston!!
Chris
in houston i would definitely give these guys a call!! hear nothing but good things from circle D.
Old 06-09-2008, 02:05 PM
omcar's Avatar
check with MTI..in Houston
Old 06-09-2008, 08:40 PM
FLT
FLT's Avatar
If you do not want a trans shipped to you........ obviously you looking for a shop to work on your ride. I would recommend either ACE or CircleD. I have had a few PM's with Chris from Circle D (located in Houston) and seemed to be a good guy. I know the guy's at ACE are stand up guy's. Actually met Gil for the first time this weekend at US 131 in Martins Michigan and talk with his head builder John every now and then. These are good people. Call them and talk over your situation. From there I'm sure you will feel comfortable taking it to either shop. As for RPM I know those boy's as well, talk to Rodney today in fact. Good guy's! But I think you were looking for a shop close to you. Good luck to you and I hope you get things sorted out. Vince
Old 06-09-2008, 09:58 PM
Fast GTO's Avatar
+1 Circle D
Old 06-10-2008, 09:25 AM
LS1Tech Sponsor
MARO-KEEN's Avatar
There are many of us in your area. Give on of us a call we will more than happy to help you out.
