Do it your self fluid exchange
A while back some one on here told me I could do a tranny fluid swap by disconnecting a line from my trans and let it run out while I pour in fresh fluid.
Does this sound like a some what of a good idea?
I got my car about a year ago and it had a flush done about 2 years before I got it(so a total of about 25K).
The fluid looks almost all pink, but has a hint of beige to it.
The reason I ask this is because I really don't want to pull the pan and I can't afford a real flush at this moment.
Or should I just wait?
i wouldn't recommend doing this... i tired and succeeded on my Taurus buts its damn near impossible to add the right amount as it coming out.. its probably not good if the level goes to high or low..
Ive done this probably 20 times. Take off the cooler line at the radiator and figure out which one is the outlet. Put a hose on that one and into a bucket. Get about 12 quarts of fluid ready. Start up the car and add the proper amount guaging from the amount of fluid in the bucket. Shut it off after adding about 10 quarts, then use the rest to top it off after putting the line back on.
I'd guess it's not a good idea. When I was installing my coolers, I started my car with both lines unhooked to determine which was the feed line and it pumped out much faster than I could have poured it back in. I'd think you'd risk losing too much. Just a thought though.
the bottom line on the tranny is the out to the cooler if this helps howevr I do not recommend this type of flush if the pan gets sucked empty you will starve the pump also the cooled fluid is for the lube circuit, you will have no lube doing this
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
