TMP helmet rule?
TMP helmet rule?
Hey guys, for those guys who are running low 13s, are they pretty strict with the helmet rule at Cayuga dragway? Rule is 13.9 and less and my car would be pretty close to that time
Rule is 13.99 and everytime I have been there they are very strict about following that rule and will boot you from the track until you get one.
If they know your car will run a 13, tech might not even let you pass inspection
Same with having a driveshaft safety loop if running drag radials
Then I got dinged and got a warning about having metal tire valves being installed on the drag radials- got a warning and was told I needed metal valves the next time I came out...sure enough, next time I went out, first thing the guy asked me.
I give the guy credit- he has a helluva memory because I went more than a month apart each time...
