ANY possible way to use factory in tank pump with return style regulator?
Im not super familiar with the 99 camaro fuel system........I have a new mallory return style regulator.......thanks for any replies
can someone who has done EXACTLY this tell me what exactly they did? We have a stock 99 fule tank/pump, with all stock lines, with a mallory 4309 regulator, edelbrock super vic intake, holley 750 dbl pumper, msd 6LS box. The fuel system is what puzzles me. Is it possible to do this with the STOCK fuel lines that were run to my old LS1 intake?
I installed a factory fuel pump in my tank. It was for an aftermarket EFI . then I did the LS swap and regulated w/return to a carb. and now back to Atomic EFI....no problems...
i have the racetronix in tank efi pump with the factory lines and used a quickfuel fuel pressure regulator and just blocked off the return side of the regulator.
this is the regulator i used
http://www.jegs.com/i/Quick+Fuel/793/30-803/10002/-1
I still have a return line im just using the factory one that is just after the fuel filter if I remember right. the fuel pressure stays where I have it set and so far I haven't had any issues with lack of fuel pressure or it creeping up.
