Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
l92 victor jr to super victor swap on my lq4 is it worth changing
Old 01-06-2015, 08:59 PM
jonz's Avatar
Default l92 victor jr to super victor swap on my lq4 is it worth changing
Have a Victor jr. Now on my 6.0 just wondering if it would pick up any switching? Combo is lq4 with milled ls3 heads and custom cam, 950 carb.
Old 01-07-2015, 07:47 AM
streetknight2's Avatar
IMO No, my car didn't pick up hardly at all and it has a 408. I went back to the Vic Jr
Old 01-07-2015, 08:51 AM
fast89stang's Avatar
Jonz....this is Benji....hes the one I told you about.
Old 01-07-2015, 10:23 AM
jonz's Avatar
Hey Benji I saw you had one for sale on facebook and I pmd u but if you still have it I'd be interested in buying it. Just like to try it out and see. But pm me on here or Facebook with some info thanks. Jon
Old 01-07-2015, 12:38 PM
The stunningman's Avatar
IF you have a lot of room under the hood it won't hurt you IMO. It will really shine if you are really twisting it out or have a lot of cubes. The underhood limitations just kill it for most not many small street cars want a 6-8" cowl and most people with a large engine space aren't turning really high RPM's.
Old 01-07-2015, 12:42 PM
jonz's Avatar
Ya my car has a 5 inch glasstek bolt on hood so I got plenty of room
Old 01-07-2015, 12:53 PM
lblevins's Avatar
I have a holley intake and ran the super and lost 2mph on the big end. Im running a ly6 with nascar ls2 rotating assembly 647/615 on 111 cam ls3 heads milled 40 with .040 gaskets and a holley ultra carb. I bought the super to install a fogger but you really need some big displacement or alot of rpm to make use of it.
Old 01-07-2015, 02:29 PM
jonz's Avatar
Ya didn't seem to like it's that's forsure maybe mine won't either that's why I kinda wanted to see what everybody else was doing with one
Old 01-07-2015, 04:03 PM
Not to Hi jack but you didnt have any problems with the .040 gaskets? i am thinking of milling my heads a little more and installing .040 gaskets too. Mines a LY6 as well. Those pistons stick out alot.
Old 01-07-2015, 05:04 PM
jonz's Avatar
Interested in that also
Old 01-07-2015, 05:25 PM
lblevins's Avatar
Im running a lunati crank rods and je pistons with valve reliefs out of a LS2 nascar engine.
Old 01-08-2015, 09:39 PM
VLS1's Avatar
For these intakes to work I think it might require a re-think in valve timing vs typical cam design when running the smaller intake.
Old 01-10-2015, 12:18 PM
6secNaLs1's Avatar
Mine picked up 11 hp on nitrous..I ran it one time at track after and spun stator tube in trans..it was on track to go faster with less power in the tune up.
I swapped back to back on dyno.. Ls2 Ls3 heads Martin Smallwood nitrous cam
Old 01-11-2015, 09:50 AM
redline2k's Avatar
We are going to run one on our 422 with gmpp cnc ls3 heads, custom crane cam ,and 1000 cfm pro-systems carb.
Old 01-11-2015, 04:50 PM
dogsballs's Avatar
Got mine and going to go on big rpm 6.0. Hand ported 5364 heads, big solid roller 700+ lift and 7700+rpm. Heads almost done and cam is on order
Quick Reply: l92 victor jr to super victor swap on my lq4 is it worth changing
