brp vs edelbrock?
Old 02-02-2009, 01:30 PM
jsn829's Avatar
Default brp vs edelbrock?
Installing a ls1 and 4l60e into a 1970 lemans sport. Whos product did you like better as far as fit? How about headers? I need to figure out witch way to go with this build and this is not a thread to rip on one or another, but I would like to here you comments. Thanks
Old 02-02-2009, 01:34 PM
pwrtrip75's Avatar
what the hell is a brp? And edelbrock what? they make tons of parts.
Old 02-02-2009, 01:45 PM
oange ss's Avatar
http://www.brphotrods.com/
Old 02-02-2009, 02:12 PM
subtlez28's Avatar
The Edelbrock headers are very nice. If you have the cash their whole kit (mounts, headers, and exhaust) will smooth your conversion.
Old 02-02-2009, 03:27 PM
jsn829's Avatar
I have talked with both companys and I like the edelbrock setup, but I dont want to notch the frame (its already powercoated). I guess I could move the acc to make it fit. The brp sits alittle different so I dont think the headers would fit right. What do you think?
Old 02-02-2009, 05:34 PM
olblue51's Avatar
Edelbrock!!! And this is coming from someone who tried both kits. But it was in a 2nd gen Camaro so I can't really comment on the Lemans kits. All I know is the Edelbrock parts are very nice quality, fit excellent and were not way overpriced.
If you don't want to notch the crossmember just relocate the A/C up high. With the money you save on choosing Edelbrock you can buy a nice relocation bracket... and even after that it would probably still be the least exspensive of the two.
Mounting the engine higher and further forward to keep the A/C in the stock location just doesn't seem like a good idea to me... looks akward in the engine bay. Plus, it usually requires you to use the LH8 oil pan which hangs too far below the crossmember.
Old 02-02-2009, 06:33 PM
cacmanjr's Avatar
I have the BRP mounts and Edelbrock headers in my 66 Skylark. The engine sits a little high in the front, but everything fits except for the A/C compressor. I should pont out that my LS1 has the Corvette accessories. The Edelbrocks are stepped headers and I like that feature. I did not use the BRP crossmember as I have a 200 4R trans. Hope this helps.
Old 02-02-2009, 06:43 PM
kevin 67/6.0's Avatar
I had the BRP monts and crossmember. The engine dose set high hope you dont mind cuting out your tran tunnel. I sent it back and got a set of monts from summit for $60 thay work great you just have to relocate you alt to top. https://ls1tech.com/forums/conversio...-chevelle.html
Old 02-02-2009, 07:35 PM
jsn829's Avatar
On an 70 a-body with the edelbrock retro kit, what oil pan do you like?
Old 02-03-2009, 12:23 AM
johnnynumber5's Avatar
kwikperformance makes the relocate bracket for the ac and its @ $200. one thing i like about the edelbrock kit from what reading i have done it keeps the motor in the same place.
Old 02-03-2009, 06:17 AM
mrtywalsh's Avatar
Listen to everybody and don,t get brped.
Old 02-03-2009, 01:55 PM
6spdgto's Avatar
so if you did go with the Edelbrock, which oil pan would you use?
Old 02-03-2009, 02:24 PM
jsn829's Avatar
Sounds like edelbrock is the one I will be using. What oil pan do you guys like?
Old 02-03-2009, 04:31 PM
mrtywalsh's Avatar
The f body oil pan fits great and does not hang below the crossmember.
Old 02-03-2009, 07:21 PM
I used a oil pan off a 2008 hummer works great. if you need a pic pm me.
Old 02-03-2009, 07:57 PM
i dont think a stock f-body pan will work with the edelbrock conversion. i was look at getting the champ pan for mine.
Old 02-03-2009, 07:58 PM
what mounts are you using on yours and how low does it hang down?
Old 02-03-2009, 08:25 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
Autokraft oil pan is what I used on my GTO. Check out my 1970 GTO build thread, link in my sig.
Andrew
Old 02-03-2009, 09:57 PM
https://ls1tech.com/forums/conversio...hevelle-2.html I got the monts from sumitt. the pan hangs down about 1.5 inchs below crossmember.I had to shem engine up about 3/8 to clear crossmember it was a little close. I like the fit alot better than BRP fit. I tried both ways.
Old 02-03-2009, 10:21 PM
the450r's Avatar
i was going to get BRP because i can retain the factory F body accessories and im doing a T56 in an auto car so i gotta cut the floor anyway. and the rear crossmember comes with it so u dont have to do alot of work setting the pinion angle. just get adjustable rear arms to set the pinion angle. Im not lowering my car so i wont have an issue with the axle being higher than the trans.
from what ive read about the Adaptor plates. They require alot of fabricating and mount/spacer problems setting the engine in expecially on Pontiac frames.
Quick Reply: brp vs edelbrock?
