fox mustang lsx Q's
Old 08-13-2009, 06:51 AM
GPSMatt's Avatar
Default fox mustang lsx Q's
Power steering?
every thread I can find people are building drag cars and doing flaming river racks.. Can you use a vette f body ps pump with the fox rack? no problems with the valving?
headers
can any one elaborate on how you have to "move tubes"
Thanks
Old 08-13-2009, 06:55 AM
jw33's Avatar
I just hooked the pump up to the rack and it's worked fine so far in about 2500 miles.
You have to modify a few of the tubes on the drivers side to clear the steering shaft if you use 351W swap headers. Passenger side gets no changes to the tubes, only a new flange.
Old 08-13-2009, 09:13 AM
Camminaro's Avatar
Yeah I am building a LSX fox myself and from what I have gathered a Fox rack will work just fine..you just have to get the lines made from the PS to the rack...I to am building a cruiser...(TT with 500-600hp) and I want all the luxuries...AC, PS, the whole 9 yards......I have suffered for 12 years now with a SBF that was quick..not fast...just quick and no AC...no PS an it gets fk'n hot in Texas....
Old 08-13-2009, 02:19 PM
GPSMatt's Avatar
does any one know the fitting size on the PS pump?
what about brackets? are you guys using the F body or vette ps/alternator brackets or are they the same?
Old 08-13-2009, 02:28 PM
ss25414's Avatar
i used a fitting kit from maximum motorsports $22.00 for the fox rack and on ebay you can buy a ls1 fitting $12.00 to make the line 6an then just make your own hose
Old 08-13-2009, 03:24 PM
Qwiknotch's Avatar
Why don't you just cut new holes on the bracket to fit onto the LS?
Old 08-13-2009, 05:01 PM
GPSMatt's Avatar
as in use the fox alternator and PS pump and make brackets?
Ive already got some of the MM adapters I used before when i ran a PS cooler didnt think about using those thanks.
does any one have any pics of their finished headers?
Old 09-10-2009, 05:48 AM
GPSMatt's Avatar
TTT on pics of finished headers
Old 09-10-2009, 08:32 AM
can'tfindausername's Avatar
I'm using truck accessories, and my ps pump is hooked up to the factory rack. On my headers the passenger side was almost a direct swap, but the driver took a little more fabbing. I extended my steering shaft a little so the rag joint would clear. I had a budget and time. I also found out that once I had the headers on, a couple of plugs were close to the primaries, so I had to use 90 degree end wires on a few. I also wrapped them to be safe
Not very good pics of the headers, but....
Old 09-10-2009, 09:22 PM
S10xGN's Avatar
Originally Posted by GPSMatt
Power steering?
headers
Thanks
Here's a (construction) pic of my Maverick with BBK 351 swap headers welded to LS flanges. Hopefully, a pic is worth 1000 words... One thing about those headers, you can mock them up as-is with the Ford flanges and get two bolts to line up (the ports will be off by 1/4" or so). The Corvette PS pump outlet is 16mm x 1.5. You can buy an adapter to -6AN from any of the major suppliers.
Quick Reply: fox mustang lsx Q's
