I need fuel line advice!
Old 01-06-2010, 08:29 PM
matt1976's Avatar
Default I need fuel line advice!
Here is what I have:
5.3 in a 69 camaro. I am using a stock tank with feed and return line. I am also going to use an inline walbro fuel pump. I am on a tight budget and don't know what I should do for the fuel lines. I do not have any experience with AN fittings and lines. They appear to be expensive at face value, but I ultimately want something that is safe and won't burst into flames going down the road. I would love to hear how you have handled your projects fuel lines. Thanks!
Old 01-06-2010, 08:53 PM
deuce4935's Avatar
You can purchase a vehicle specific kit from S&P for your f-body swap and it will have everything you need.
Old 01-06-2010, 09:09 PM
matt1976's Avatar
looked at them, but they are too pricey for my wallet
Old 01-06-2010, 09:28 PM
aixgelo78's Avatar
look thru this thread... https://ls1tech.com/forums/conversio...ap-thread.html
He took stainless steel 3/8 hard line to run his lines. This is what I plan on using for my build since most of my lines are 20yrs old.
Old 01-06-2010, 09:36 PM
dec010974's Avatar
Default fuel lines
hello matt1976. one option you may have is use the existing line with a intank fuel pump. in my application, '87 c10, i dropped the tank, replaced the fuel sending unit, added walboro electric fuel pump. fuel line to the rails needs to be at least 3/8 of inch, with 58 psi. the return line can be 5/16. walboro pump cost $125 or less. you may can reuse the the fuel sending unit. if pics are needed pm me. i ran braided fuel line for my application. good luck.
Old 01-06-2010, 11:29 PM
ChrisBorsheim's Avatar
..what's s&p?
Old 01-07-2010, 12:16 AM
supershift67's Avatar
I hooked the line right on to the stock pickup. then ran a rubber line to the fuel pump and used rubber fuel injection rated line from the fuel pump to the adjustable professional products regulator. then used rubber fuel injection line to the stock 3/8 line to the front. I run a vented gas cap and hooked the return to the vent hose on the tank.I hooked into the stock fuel line on the engine with rubber fuel injection line here also but I am going to change it I think. I do have all the lines flared and double clamped. this was the cheapest way to go for me and it works great but I will see what other people have done. I think it was 100 for the pump and a 100 for the regulator.Pump and regulator are in the back by the tank with single line going to the engine. I wanted to make sure I could adjust the fuel pressure so I did not use the corvette regulator. I figured for 40 more dollars it was just easier.
Old 01-07-2010, 12:21 AM
battsup's Avatar
Originally Posted by ChrisBorsheim
..what's s&p?
Surprisingly & Positively expensive
lol, i believe it stands for street and performance.
Old 01-07-2010, 12:30 AM
the professional products part numbers are 10671 for the regulator and 70160 for the fuel filter. I used a walbro pump also.Good luck with your project.
Old 01-07-2010, 12:29 PM
ssduane's Avatar
look at Summit Racing for AN fittings, they are about half the price (their brand) then the Russel fittings.
Old 01-07-2010, 03:06 PM
lamdenali's Avatar
S & P stand for ripoff LOL. I use Braided line and only cost around $125 with all the fitting from Jegs. make the car look cleaner
Old 01-07-2010, 05:16 PM
Pro-Tour Heavy Chevy's Avatar
I'd like to see pic's of this mod since I'm doing a 71 Chevelle and have a fairly new tank already. I'll Pm You
Old 01-07-2010, 10:12 PM
JJFarmer's Avatar
You should look at the Corvette filter. It's a filter with built in regulator and has the return to the tank line built in. For $30 + shipping. Mount it close to the tank and run one line to the fuel rail...done.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
Check this thread...
https://ls1tech.com/forums/conversio...34-ebay-2.html
Old 01-08-2010, 11:20 AM
lamdenali's Avatar
That"s exactly what I did to my 67 Chevelle and now am doing the same to my 70 Chevelle
Quick Reply: I need fuel line advice!
