New ECU Pins? (Adding Fan Control)
I have the proper crimper, but where can I find new ECU pins? I would like to add fan control to my harness, but don't want to splice wires if I can help it. A part number would be even better.
While Im asking, is it better to run the fans on their own with a sensor, or allow the ECU to control them??
I have no problems with splices. Im just picky about details, and when the Jeep is several miles from civilization, I don't want to worry about a bad splice. Normally I would use splices as needed, but Im tryin to avoid them if I can with this build.
On my wiring I took some of the unused wires/pins I had removed from the harness that weren't being used, such as EVAP stuff or A/C stuff, and added them at the proper pin locations for fan control. You will have to have the PCM programmed for fan control if it did not have it previously.
I have a bunch left over, and I have a habit of not throwing things away. Let me know what you need and I can most likely help.
