Russell AN to Quick Disconnect Problem & Fix!!
Old 05-22-2012, 12:47 AM
SS409's Avatar
Default Russell AN to Quick Disconnect Problem & Fix!!
I found a problem with a Russell Quick Disconnect Fuel Line Adapters. I have been reading about some problems they have been having with them coming off, because they are not seating all the way on to the connector. I have found a problem with one of the connectors part #640863 Black -6 an to 5/16. The plastic clip still had plastic in the seat area, and was not allowing the clip to seat properly. I have made a video of this problem, and a fix for it. I hope this helps anyone that has the same problem as I did.
Here is Pic of Adapter:
Here is Video: Part 1 & Part 2
http://www.youtube.com/watch?v=xiaFuZI-G6Q
http://www.youtube.com/watch?v=AWhoILw6Oc0
Old 05-22-2012, 08:29 AM
Old Geezer's Avatar
Also, there's a "new" version out, with metal, screw in retainers....
5/16 to -6 644113 Black. 644110 Blue.
3/8 to -6 644123 Black. 644120 Blue.
Old 05-22-2012, 01:20 PM
SS409's Avatar
Thanks, For the info!
I have seen those, but haven't tried them yet. It looks like a secure setup.
I think the plastic clip ones work fine, as long as they are seated all the way.
The Automakers have been using them for 20+ years without problems.
Old 05-22-2012, 06:02 PM
Old Geezer's Avatar
For those with the plastic clips, there are replacement clips made of metal...Got some at NAPA.
Old 05-27-2012, 04:31 PM
SS69LS1's Avatar
you have a part number for the napa metal clips?
Scott
Old 05-27-2012, 04:56 PM
superdave84's Avatar
I am putting these things on this Friday. I'm glad you posted this so I can check the little plastic clips before I put them on. Thanks a lot.
Old 05-27-2012, 05:08 PM
Rocketrod's Avatar
Don't buy the old version with the plastic clips, buy the new version Old Geezer mentioned, which are the one I used. The new ones are pretty much idiot proof as far as installing. Here is a link http://www.summitracing.com/parts/RUS-644113/
Old 05-27-2012, 06:04 PM
CFster's Avatar
I had the plastic clip version pop off while driving and spray gas all over a hot engine. I was overjoyed when the new version came out.
Old 05-27-2012, 08:36 PM
lizeec's Avatar
I agree just buy the new updated version, its a much better idiot proof design. Russell knew they had a problem with those plastic style clips, they are probably fine but in today's marketplace you have to make things with idiot proof installation procedures.
My guess the only reason they are still selling the old style is they had about 25 bazillion made from their supplier in China and are just waiting to run out of stock and then discontinue the old style.
Old 05-27-2012, 09:20 PM
TX RED's Avatar
Im replacing mine...was going to fire up the car this week
Old 05-27-2012, 09:34 PM
ZTwentyAteU's Avatar
I had one of the russel plastic clips blow off on a boosted trans am and burn it to the ground on the side of i65..and I mean burn it to the dang ground. I wouldnt trust it anymore than I can throw it
Old 05-30-2012, 11:18 PM
CMKworm's Avatar
Guess I got lucky that my car didn't burn when my fuel line blew off.
Old 04-09-2015, 12:06 PM
Scarebird's Avatar
Add me to this failure list - popped off the filter when starting and stranded me with a big pool of fuel under the Trans Am.
Thanks Russell!
Will rewire to include a no-oil pressure cutoff for fuel pump.
Old 04-09-2015, 05:42 PM
Tranz Zam's Avatar
I'm currently running the old plastic style ones. So what I did was create a little metal plate that slides onto the AN line, then I put the fitting on the line. After that I slide the plate up right behind the fitting and zip tie it to the fuel rail. Its never coming off.
I do want to switch to the new style though. Even with the bracket I made I still don't trust them.
Old 04-09-2015, 07:20 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Earl's make a nice alternative. You actually need a tool to remove it, plus it has the extra retaining clip.
https://holley.com/products/ls_power...ts/AT991966ERL
Andrew
Quick Reply: Russell AN to Quick Disconnect Problem & Fix!!
