LS1 fan ?
good diagram...
doing it like that makes it so that only one fan can be on at a time....
need power to go to 30 on both relays...and 87 to go to each fan...
the LS1 will want both fans on in high mode
stock pcm supplies a ground to enable the relay
personally, I prefer to use a 12v switched source for the relay to turn on instead of a ground to enable it...but you have to either have a separate switch, or be using a different controller for the fans.
Yep, read it fast and thought he meant one or two fans not relays. Two speed fan should have one speed at a time.
No ECM then go here http://www.davebarton.com/pdf/coolingfandiagrams.pdf Several different setups
