My track/street 240sx LS Swap
Old 06-10-2013, 09:09 PM
cosmo22nov's Avatar
Default My track/street 240sx LS Swap
Well I've been floating around on here doing research for a while now. So I finally decided that I should start my on build thread. I've had the car since last fall and have a hoard of pictures! SOOO for all of you who love pictures this thread is for you. But please bare with me as I try to catch up posting all of them.
But my car is a 1989 Nissan 240sx coupe, and here it is right when i picked it up
I managed to nab one with a fully functional HUD and digital speedo
So I started ripping the interior out
And I picked up an LS1 from a camaro for $500 with a spun rod bearing and started tearing it down
Old 06-10-2013, 09:31 PM
cosmo22nov's Avatar
Got the front end torn off
Bye bye 4 cylinder
Front suspension removed
Rear suspension/subframe removed
Removed some more parts, its getting closer to a bare shell. I also got rid of some brackets in the engine bay I wont be needing.
Removed the dash and everything behind it
Looking pretty much like a bare shell now
Old 06-10-2013, 09:42 PM
cosmo22nov's Avatar
Nasty rust hole under the battery tray
Started removing sound deadening. Dry ice works like a charm!
Got it loaded up to head out and get sand blasted
Now for a look at some of those bearings, YUCK!
Old 06-10-2013, 09:53 PM
cosmo22nov's Avatar
Now for the fun stuff! Who wants to see some go fast goodies and swap parts?
First off my lovely package from texas speed! PRC stage 2.5 5.3 heads, 228r cam, ported ls6 oil pump, hardened pushrods, ls2 lifter trays, and ls7 lifters.
Next I got my nasty crossmember all cleaned up
And here is the mount kit from Holley/Hooker Headers with poly mounts
And here is the canton swap oil pan
Old 06-10-2013, 10:10 PM
cosmo22nov's Avatar
And here's the shell back from the sand blaster. And man can I say it does suck trying to clean the sand out of this thing!
And here it is after being sprayed in primer.
And back in the shop
And here is the bigger and much stronger Q45 LSD with J30 axles
The rear subframe with weld-in reinforcement plates
Got the T56 cleaned up a bit. (it was rattle canned black by the previous owner)
Got some more pieces sand blasted.
Old 06-10-2013, 10:24 PM
cosmo22nov's Avatar
And now for some more awesome LS engine goodies!
First is the Mahle powerpack piston kit
And here are the solid suframe bushings ans the solid differential mount bushings.
The Fidanza Aluminum flywheel. And I really like the removable clutch mating surface.
And the scat I-beam connecting rods
Old 06-10-2013, 10:25 PM
cosmo22nov's Avatar
So I got about half the pictures up but its bed time for me, Ill continue posting tomorrow.
Old 06-10-2013, 11:04 PM
TX RED's Avatar
nice!!! subscribing
Old 06-10-2013, 11:09 PM
thunderwagen's Avatar
Really nice start to your build! And nice shop
Old 06-11-2013, 08:35 AM
cosmo22nov's Avatar
Thanks! And that is my Dad's shop, I'm very lucky to be able to use it. By far the best conditions I've ever had to work on a car.
Old 06-11-2013, 08:45 AM
cosmo22nov's Avatar
Here is my Chase Bays conversion harness with dakota digital tach and speedo conversion boxes. This is one of the cleanest harnesses I've ever seen and am very happy with it.
Energy Suspension poly bushings for some of the rear suspension
Talked to a buddy down in Missouri who got his hads on a diff from over seas with a high capacity cover and he cant use it for what he is doing, so I am waiting for the cover in the mail to use on my car.
Here are my seats a seat brackets. I love the seats but hate hoe high the brackets put them. So I may be looking into alternative mounting options later down the road.
Old 06-11-2013, 10:50 AM
dvdswan's Avatar
Nice work so far. I would love to have a shop like that too. 2 car garage just can't compare with that. What color are you planning on?
Old 06-11-2013, 01:44 PM
cosmo22nov's Avatar
Thank. And I'm going for a satin black. I don't quite want flat but not gloss either so I'm going to try to land somewhere in between. The car will also have a rocket bunny wide body kit. Hopefully Ill have the rest of the pictures uploaded tonight so everything is up to date.
Old 06-11-2013, 04:33 PM
TopNotchLSX's Avatar
As I scroll throught the build I can't help but notice the awesomeness of the shop!...with attached stables. Very classy! Great build so far, looks like you are making progress.
Old 06-11-2013, 05:55 PM
curbcheck's Avatar
damn, you doing it right. can't wait to see the outcome on this. i love coupes
Old 06-11-2013, 07:45 PM
brewster240's Avatar
the stronger part of the q45 diffs is the outputs and axles, which dont work with j30 axles.
Old 06-11-2013, 07:53 PM
rotor vs. piston's Avatar
Any expense spared? Very nice!
Old 06-12-2013, 08:46 AM
cosmo22nov's Avatar
Engine parts back from the machine shop
Spec stage 3 clutch next to the Fidanza flywheel
Checking out the mount kit with the crossmember. I will have to fab up a good skid plate... The oil pan just barely dips below the crossmember.
Old 06-12-2013, 10:19 AM
cosmo22nov's Avatar
I am using a later year Q45 diff (97-01) so I wouldn't have to source a twin turbo 300zx axle shaft. The later year diffs can be used with 92-94 j30 axles. I have a 98 q45 diff and 93 j30 axles.
http://www.ka24development.com/vlsd.html
Old 06-12-2013, 10:24 AM
cosmo22nov's Avatar
And thanks for all the comments guys. It's really appreciated, I'm getting close to having all the photos uploaded. And yeah like I said its a very nice shop. The bottom level is divided in half and one side if for horses and the other half is the car shop. The upper level is storage and my mom's art studio.
Quick Reply: My track/street 240sx LS Swap
