LSeX Boosted Notchback. 5.3,TH400, etc
Old 03-31-2014, 11:24 PM
FrossB's Avatar
Default LSeX Boosted Notchback. 5.3,TH400, etc
Guess its time for me to make a build thread! Not a super original one as far as a Conversion goes but owell.
So i picked up a super clean 1993 LX Coupe for 700 dollars. It had the 2.3, auto, blue interior. It ran and drove perfect. No rust. One small dent on the roof. Really good condition for 165k on the clock.
My build is as follows:
It will be a Street/Strip setup. Something i won't drive daily but will be on the street with occasional trips to the drag strip.
Stock bottom end 5.3
LS6 Valve Springs and Head Gaskets
3" intercooled
LS1 Intake
Ebay head studs
Ebay GT45…or possibly a S475 if i decide i want to spend a little more.
Siemens Deka 80's
Holley fuel rails
Sumped fuel cell
AEM 380 Inline Pump
E85
TH400 with Freakshow Performance converter
Stock 8.8
275/60r15 radials
Keep in mind this will be a budget build. Some things i won't skimp on (like fuel system) but some corners will be cut!
Id like to have some 10 second passes once done at my local track, Bandimere Speedway. My goal horsepower is around 500hp at a low boost level (8-12psi)
Im trying to get the car super light so i will need less horsepower to reach said track time. Id like to see 2800 with me in the car. I weigh 200 pounds.
Feel free to toss in any advice, tips, and experiences with your conversions as this is my first.
Thanks!
Day i got her home!
Getting ready to pull the motor!
Got it pulled a few days after picking it up…silly 4 cylinder
New power plant. 2001 5.3 Vortec. 210k miles. Had great oil pressure and compression on all cylinders. Paid 250 bucks for it complete with all accessories, harness and pcm!
Started to tear down the engine
Picked up some really good condition LT1 fans and radiator for 50 bucks!
Got the AJE Racing K Member, LS mounts and manual rack! so purdy
Doing some cheap-ish mods while i save up for other things. Painted the valve covers a textured black
For funsies
Im thinking purple and black for the engine bay scheme. Going with the brighter purple
Decided i would somewhat clean up the engine bay. Welded some of the smaller holes in the bay. Not getting crazy.
Cleaned, sanded and primed the bay. It will soon be Satin Black.
Made a custom panel to help clean up the bay. Still need to weld and prime it. I also have a few Scott Rod Fab pieces that will go on the firewall area to aid in covering the holes.
That is as far as i am at the moment. Wont be a speedy build as i am trying to do it on a budget.
Old 04-01-2014, 05:13 AM
dmcdevin's Avatar
Lookin good so far! You should be able to hit your goal pretty easy. I'm doing a similar build only with a 6.0. And as for your converter I'd check out ptc and circle d both are great company's to deal with and you definitely want a quality converter. Good luck on your build!
Old 04-01-2014, 09:57 AM
FrossB's Avatar
Yea i emailed PTC about a trans and stall for my setup and never heard back. Probably just give them a call. I've heard good things about them. Thanks for the recommendations
Old 04-04-2014, 09:25 AM
zacht's Avatar
Looks good man! Thought you were set on a TH350?
Old 04-04-2014, 09:27 AM
zacht's Avatar
Woa nevermind...you did say 400...
Old 04-04-2014, 09:29 AM
FrossB's Avatar
I'm not set on either one. I just liked the 400 since they hold more power generally.
Old 04-04-2014, 08:40 PM
FrossB's Avatar
So my next area of parts to buy is the fuel system...specifically the pump, regulator and fuel cell. But to stick with my "budget" build, I'd like to not do a fuel cell if I don't need to. That being said, I'm considering the Aeromotive 340 for in the stock tank. My question to swap guys is will the stock foxbody fuel lines suffice for my goals? If so, what needs to be done to adapt to the stock 5.3 truck fuel rails. They have a built in regulators so I shouldn't need an aftermarket correct? If not, will the corvette filter/reg work with boost?
Old 04-05-2014, 04:26 PM
M.BOZZ's Avatar
Nice car, that's clean. What headers are you going with ?
Old 04-05-2014, 04:33 PM
FrossB's Avatar
Thanks man!
I'll be running flipped truck manifolds for the turbo setup
Old 04-05-2014, 06:44 PM
dmcdevin's Avatar
I'd check out the holly dominator pumps they're pretty badass for the price and it can run e85 if you ever decide to go the route later on
Old 04-05-2014, 08:19 PM
FrossB's Avatar
Yea i plan on going e85 so that would be something I would need to account for. I should probably just run a fuel cell with correct lines since I will eventually be doing that anyway lol
Old 04-05-2014, 10:40 PM
dmcdevin's Avatar
And if your wanting to keep the stock style gas tank Glenns performance sales one that it already sumped
Old 04-07-2014, 10:04 AM
REDCYCLE13's Avatar
My gutted foxbody with LS3, powerglide and Novi2000 blower weigh 2844 with me inside, and I'm 200lbs. The car does have a ten point cage, but the only place I could save more weight would be gutting doors, and fiberglass body panels. Everything else is already gone. Not much of a street car at that point, but it is tagged and insured. Good luck with your project.
Old 04-07-2014, 12:56 PM
geoff17's Avatar
Wow what's all done for weight reduction?
Old 04-07-2014, 12:59 PM
geoff17's Avatar
Your goals should be easy to attain. My stock bottom end lq4 with a tc76 through a full exhaust with pump gas and no meth netted me a 9.8@140 in my notch. Stock 4l80 with a ptc converter and stock 317 heads with a tooley spec'd cam. Mine is full street trim and has ac (only thing is its manual steering, but with skinnies you can barely tell). It made 585rwhp on 15psi which was the 9.8@140 pass. Mine weighs 3160 with me in the car and I weigh 160.
Old 04-07-2014, 08:30 PM
REDCYCLE13's Avatar
Weight reduction: everything removed from car ( I mean everything ). Replace with chromoly K-member, all chromoly suspension arms, 10 point chromoly cage, add one aluminum seat, and just the plastic shell of the dash with six Autometer gauges.
[IMG][/IMG]
Old 04-07-2014, 10:14 PM
FrossB's Avatar
mine shouldn't be too far off that then! Your ls3 is a little lighter but I believe the glide is heavier than a TH400 (I think). I have a tubular k member, manual rack and no AC. And my interior will look pretty much like yours minus the cage. I'll probably paint the floors so it doesn't look SO bad haha.
Old 04-07-2014, 10:18 PM
FrossB's Avatar
What stall speed you running? And rear gears?
I'd be giddy like a schoolgirl if I dipped into the 9's. And I'll hopefully be a few hundred pounds lighter than you which will make it a little easier. Thanks for the input!
Old 04-07-2014, 10:34 PM
M.BOZZ's Avatar
How did your aje bolt up ? My aje looks like my 7 yr old welded it up. Control arm brackets not even close. Maybe I just got a bad one. Keep posting pics
Old 04-07-2014, 10:37 PM
FrossB's Avatar
I actually haven't bolted it on yet. I wanted to get the engine bay painted first. I'm hoping this weekend I will get it installed tho. I'll post pics for sure!
Quick Reply: LSeX Boosted Notchback. 5.3,TH400, etc
