Air intake plumbing/system?
At frist, I just order some rubber elbow from Jagsthatrun..
A 90 Elbow - 4" to 3 1/2" for the TB to MAF then to a filter.. but that didn't last long..
then I added a 3 1/2" 90, a 45 3 1/2" elbow and from there added my own Air box that is designed to match up with my Chevelle Cowl Induction hood.
Just a suggestion..
Just a suggestion..
Do you happen to know how accurate your MAF is in that configuration? I've heard that you'll experience a lot of MAF error when trying to read actual airflow with that drastic of a curve right in front of it, although haven't seen many people come back with hard data.
Have not had it on a dyno or anything. And I don't feel it is any issue as I don't do any street racing, but have had it on the 1/4 mile.. only in street trim and just burning up the tires in three gear.. so.. not a very good outting in street tires.. but it pulled pertty good all the way to about 6200+.
I have not scanned it in a while or at WOT.. so I really can't comment on the MAF errors related to the not striaght air flow... but none are being recorded.
For the Air cleaner setup.. It is a custom design that I made, follow my link in my sig to page #10. It show the mounting and air cleaner box. It is basically just like two straw hats.. one inside of the other.. with a oval tube joining the two to pass the filtered air to the MAF/Throttle Body.
If you have more question, ask away !
that is really awesome, I love your car
btw my car would have looked just like yours before you started, same copper color with black vinyl
good riddence...
I don't do those type of colors at all, even hate the sunset orange metallic trans ams and stuff
good riddence...
"is there anything wrong with just putting the filter on the maf? or does there need to be tubing first?"
I would not thing so sense my 5.3 in the 2002 Z71 has the MAF connected to the filter box from the factory. I just installed my JTR elbow same as Bczee has then MAF then carbon fiber (look a like) filter assy. I'm going to connect the filter to a PVC cleanout T and then duct to the inside lights on my cutlass. I purchased some of these on E-bay. I was really impressed with this flex hose product. You can shape it and it stays the shape.
http://cgi.ebay.com/ebaymotors/ws/eB....cWON.m313.lVI
here is the filter assy also purchased via e-bay. I drilled a hole in it and mounted my IAT sensor in the filter assy.
