Door speakers for a 4th gen vert??
Am I correct to assume the door speakers on our verts are the same as the non verts with a Monsoon? Blew on at the gathering and need a good place to get a replacement for the fronts. Any thoughts? Don't want to change anything else.
I've bought ones out of a hardtop and they worked fine. Don't bother replacing them with stock ones though or they'll just blow again. Any aftermarket 6 1/2 inch speakers that are 2 ohm will work fine with the stock monsoon sounds system. I bout some infinity ones and they sound a little better than stock and won't blow.
Factory OEM replacement speakers
Originally Posted by 99'CajunFirehawk157
Are you saying someone makes upgraded stock type speaker w/a 12 month warranty?
YEP ! Check with your nearest Chevy dealer. About $48.00 bucks .
