Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
car will not start just clicks
Old 04-12-2011, 03:50 PM
BlKOMAR's Avatar
Default car will not start just clicks
How hard is it to change the starter on a 2001 C5Z with 1 7/8 kooks
Old 04-12-2011, 03:57 PM
egott_91's Avatar
If it's anything like my 3rd gen was, it was a tight location. Of course I didn't have longtubes, but we had to loosen my y-pipe to move it to get to the starter. It was a fun afternoon in my friends driveway, cause that's where it finally gave up.
Hope it's not too hard for you though. GL.
Old 04-12-2011, 06:13 PM
BlownVette 2001's Avatar
It's a PIA with headers. You're going to have to drop the passenger side header to get at the starter.
Make sure you disconnect the battery before you start.
Old 04-12-2011, 07:31 PM
V-seriesTech's Avatar
word.
kill battery, if you CANNOT WIGGLE your way in there some way, some how,...
then drop X pipe, jus enough to where you can remove the header collector out of it,...then (i'd remove your spark plugs to avoid cracking them but,..thats just an advisory,..not something you MUST do but, I would) remove all header bolts except the furthest forward,... you should be able to now let the header hand enough, to remove the starter.
MAKE SURE you don't over tighten the small NUT on the starter...it's very easy to crack the stud off.... been there, broke that.
Have fun.
Old 04-13-2011, 01:21 AM
SStheBest's Avatar
Just curious....have you done any trouble shooting before you just go yankin out the stater?? Clicking usually means dead battery. Bad starter has a grinding sound. (in my experience)
Old 04-13-2011, 12:17 PM
BlKOMAR's Avatar
i really dont think its the starter i think its the solenoid
Old 04-13-2011, 04:57 PM
C5natie's Avatar
I agree. When a starter is dead you get nothing when you turn the key. Clicking really sounds like a dead battery. Just jump it and see if it starts. You'll be suprised.
Old 04-13-2011, 04:58 PM
C5natie's Avatar
Solenoid wont click.
Old 04-14-2011, 06:18 PM
Any updates ?
Old 04-16-2011, 01:36 PM
rms-man's Avatar
If it clicks once when you turn the key it's usually starter related.
If it clicks several times when you turn the key it's usually battery related.
FYI: If your's is one click then I bet the starter positive cable is loose on the stud. If you disconnect battery and then reach in from the bottom you should be able to tighten that 13mm nut and might save you the hassle of dropping that header.
You can also get a really long straight prybar or similar item and bang from the topside the top of the solenoid while someone turns the key at the same time and if it fires up then that's also a sign of starter issue. But the loose 13mm can cause that to happen as well.
Old 04-16-2011, 03:24 PM
1c62nv's Avatar
The solenoid serves two purposes. Once youve determined that the battery voltage at the solenoid is sufficient and you here the click or clunk sound it could be the contactor plate in the back of the solenoid. The solenoid pulls the bendix to engage the rig gear and at a predetermine travel will hit the contact plate in the rear of the solenoid body. The contactor completes the pole circuit which allows the starter motor to run, thus starting the engine. It is common for the contactor to get fouled up with arc deposits and corrosion. Still requires the starter to be removed for repair.
Old 04-18-2011, 11:05 AM
BlKOMAR's Avatar
thank you brother
Quick Reply: car will not start just clicks
