How did I do?---> Boltons,ss3600
Old 10-12-2008, 09:58 PM
Silver2000WS-6's Avatar
Default How did I do?---> Boltons,ss3600
Hey guys I finally got to go to the track the other night for the first time in a while. Here is what is done to my car.
3.42's
Yank ss3600
ls6 intake
slp cold air
p/p throttle body
full exhaust "QTP's with a Borla"
thermostat
tune
stock suspension without front sway bar
et street radials on stock wheels
3300 lbs without me and I am about 180 lbs so race weight----> 3480 lbs
That is all that is done to the car but I do not know that DA. I live in North Alabama and it was like 65 degrees and the track condition was so so. To the goods.
60ft------> 1.7014
1/8-------> 7.714
mph------> 89ish
I had two runs like this the rest were like 1.72 with a 7.75. My best runs came from launching at about 2000rpms and the 1.72's came from about a 1000rpm launch. This was my first time out on tires/converter so I didn't know how to launch it. I am going to keep playing with it and see if I can figure it out. How are my times compared to others? What about my 60's is there much more? What kind of 1/4 mile times would this net me? Sorry for all the questions I am just curious what everyone thinks any positive critisism will be appreciated.
,Chase
Old 10-13-2008, 08:48 PM
No input guys?
Old 10-13-2008, 08:53 PM
philsblwnz28's Avatar
Wow, sweet wish i had your mods
Old 10-13-2008, 09:07 PM
Shon Herron's Avatar
3150ish #s
Stock LS1, LS6 intake, P&P TB, Pacesetter LTs/Y-pipe/Aerochamber in stock location, LT1 CAI, QA1 4 corners, Spohn TA/Drag Bar, HerronPerformance LCA/PHR, 4.10s, Built A4/PT4400, SD Tune just to get it to idle and get some miles on the set up in my 97Z28.
1.59/7.51 @ 90
Old 10-13-2008, 11:35 PM
Thanks. Yeah deals really lined up for me when purchasing my parts.
Old 10-13-2008, 11:38 PM
Originally Posted by Shon Herron
3150ish #s
1.59/7.51 @ 90
Maybe I am in line. You are a lighter with more converter and suspension but a couple tenths quicker. Looks like you have a cool car.
Old 10-14-2008, 06:30 AM
It's actually almost a POS, LMAO.
the 97 was the bolt on record holder with the LT1 (11.80 @ 113) and sat for 2+ yrs being "parted out", guy never came and got the bulk of the car so I found an LS1/A4 set up and put it all together.
Going TH hoping to run 7.4s or better....
Car info
Old 10-14-2008, 05:54 PM
11SECSS's Avatar
Just keep working on the 60ft and try different air press to see which works best.......
Old 10-14-2008, 10:41 PM
eric01ss's Avatar
try air pressure at 15 and launch at 2200 rpm yet nice times for what u have done
Old 10-14-2008, 11:55 PM
TORK?'s Avatar
Nice times man! You can probably get that 60' down even more
Old 10-15-2008, 12:10 AM
CamaroRacing12's Avatar
sweet times man.... they look right on par for ur mods and weight.... probably would be a 12.2 or 12.1 in the 1/4 mile i ran a 12.49 1/4 with a 7.91 1/8th, with about the same mods and weight as u... but then again u have an ls1 and i have a lt1
Old 10-15-2008, 09:10 PM
chrs1313's Avatar
havent seen you post in a while...how is the car doing...i see you have a 10 second under your name...
Old 10-15-2008, 09:34 PM
MYSTIC-1SC's Avatar
nice times
Old 10-16-2008, 09:33 AM
About what kind of 60' should I shoot for. I am just not sure what I can get with this weight, stock suspension, and bolt-ons.
Thanks, Chase
Old 10-16-2008, 09:48 AM
if you are spinning, then there is more in it, if you are not then you might be as good as it gets but 1.6s should be easy with some changes.
Old 10-17-2008, 11:29 AM
Yeah I am not spinning so I know traction isn't an issue. I was just curious if that is about all I should expect out of that converter/weight/power/suspension set up. I know there is many variables but I was just making sure I wasn't obviously bad off.
Thanks, Chase
Old 10-17-2008, 11:35 AM
I was spinning bad last night, was anywhere from 1.64 to 1.8x, all 8 runs in the 90MPH range, but et was 7.5s to 7.8s depending on how much spin.
I have cords showing on BFG DRs now so I will move to a bias ply and it will help!
Old 10-18-2008, 01:35 PM
Yeah I went from 8.1 to 7.71 just by swaping from bfg's to Mickey's. Sounds like nice runs.
,Chase
Old 10-18-2008, 01:40 PM
,Chase
I am going to test some stiff wall ET Drags, buddy has some mounted on same rims I run so I will try those and decide what route to go, be a couple of weeks though....
Old 10-19-2008, 11:33 AM
Cool let me know how it goes.
,Chase
