11.36@119 cam only!
Old 03-24-2013, 12:46 PM
Joe Spinners's Avatar
Default 11.36@119 cam only!
I ran the car this past Friday at the local dragstrip. First pass was a 11.36@119 bouncing off the 2-3 limiter...I ran a second time and also had 2-3 issues and let off right before the finish line and ran a 11.4@111.
Here are the times:
Run 1:
60ft - 1.514
330 - 4.530
1/8 - 7.177 @ 92mph
1/4 - 11.369 @ 119.68
Run 2:
60ft - 1.577
330 - 4.594
1/8 - 7.230 @ 92.18
1/4 - 11.463 @ 111.89
According to dragtimes.com, it was 80.6 degrees F, 61% humidity, 29.61 in pressure. I used their calculator and DA that night was around 2300. According to the 1/8th mile on my first pass, I should've ended up at about a 11.1-11.2 had it not bounced off the rev limiter a few times. Any thoughts? Mods are in sig by the way. Raceweight was at approximately 3220.
Old 03-24-2013, 01:59 PM
speedshifterNC's Avatar
great job Im right there w you but 3350 and 6spd..some people are tired of the cam only genre but I continue to be impressed at how these "old" lswons run w just a cam..I was running w new 5.0s on gas last night at the strip..cut a 7.20 @ 97 thru 4 gears..get off that limiter and you'll pick up a few tenths
Old 03-24-2013, 02:48 PM
murphinator's Avatar
havent experienced it myself but read recently if you manually shift or leave in d it seems to have 2/3 shift issues , leave it in OD
also read on a hard launching car people are running the pump dry in the trans and to overfill it 1/2 quart or so.
straighten out the shifting you will be 11.1/11.2 for sure
Old 03-24-2013, 04:55 PM
You're car has some good mph! You're right man, I am more than impressed with how both our cars are running. Hopefully I'll take care of it pretty soon and make some passes.
Old 03-24-2013, 04:58 PM
I leave it in OD, I keep hearing mixed things leaving it in D. I've tried overfilling the trans with fluid and no luck
I may try a deep pan and see how that works!
Old 03-25-2013, 06:34 PM
Cra-Z Larry's Avatar
Some impressive times there OP, looks like I need some wieght reduction!! I recently read about the 2-3 shift problems but only had it happen on low 40* days when the trans temp was cold, maybe 3 times in 10 yrs.
Old 03-27-2013, 10:52 AM
Mr. Trick's Avatar
Nice times man. Man I wish I lived at a lower altitutde.
Old 03-27-2013, 11:50 AM
Tan327's Avatar
Sounds like our cars are pretty similar man, all the way down to the weird 2-3 issue. My tune is on, my trans is built by one of the best, but on a hard launch that dead hooks it just doesn't like the 2-3 shift, no issues any other time.
You're 100lbs lighter than me, mind posting your weight reduction and your weight? I'm 150lbs, 3320 raceweight.
Old 04-01-2013, 11:39 AM
Thanks guys!
Tan, we definitely are very similar in times. My raceweight is approximately 3220 (I'm 220-225). All interior was stripped, except for the dash, door panels and center console. I run Hoosier tires all around with Weld RT-S wheels. I have a fiberglass hood that weighs about 15lbs or so and a 11lb battery that was on the car as well. All suspension pieces (k-member, u/l control arms, sfc etc.) consist of UMI components, except for those provided by MWC as i have one of their 9" setups. A/C has been removed. AIR/EGR have been removed as well. I'm sure I'm forgetting minor things but that pretty much sums it up.
Old 04-05-2013, 03:26 PM
qwk93ta's Avatar
You've got some nice 60' times!!!
Quick Reply: 11.36@119 cam only!
