3.42 to 4.10 gear results!
Old 07-14-2013, 09:06 AM
SWEET98SS's Avatar
Default 3.42 to 4.10 gear results!
So I recently found some 4.10 gears for $50, decided to jump on it and install them.
Im pretty happy with results for the price I paid. All suggestions are welcome how to improve my times.
The DA was around 2300
Tire pressure was the best around 23.5 hot.
I did hear my tires spin on the 1st 2nd shift so I am loosing some time there.
http://www.youtube.com/watch?v=HF3lO...ature=youtu.be
http://www.youtube.com/watch?v=8mZTj...ature=youtu.be
http://www.youtube.com/watch?v=eYjVU...ature=youtu.be
Old 07-14-2013, 09:21 AM
HCI2000SS's Avatar
I make similar power as you with my HCI build, and love my 4.10's. Are you on street tires?
Old 07-14-2013, 09:23 AM
SWEET98SS's Avatar
I am on Nitto 555r's, they suck at the track. I am thinking of getting some slicks, too much work launching on these. Also was wondering what a 28" tall tire would do with 410 gears, I will have to do so research.
Old 07-14-2013, 09:36 AM
lemons12's Avatar
Looks like the majority you gained was from the better launch.
.4 is about what I attribute to the better launch.
Old 07-14-2013, 09:46 AM
SWEET98SS's Avatar
I say its a combination. My first pass with the new gears was a 2.19 60 ft, 12.62 ET, 118.11 mph. 1/8 mile ET 8.38 at 91.65 mph.
Old 07-14-2013, 09:52 AM
HCI2000SS's Avatar
Well I run the 555R's too, so I know exactly what you mean! I drop my pressure to around 17lbs, and heat them up good. Are you on the stock suspension too?
Old 07-14-2013, 10:01 AM
SWEET98SS's Avatar
I have BMR springs, Koni shocks and an adjustable panhard bar, thats it.
Old 07-14-2013, 10:08 AM
lemons12's Avatar
.1 in the 60 is roughly .2 on the big end.
Old 07-14-2013, 10:10 AM
HCI2000SS's Avatar
With those tires and suspension I personally think 1.8 60ft is within total reason. Hopefully i'll be able to comment more when I get to the track
Old 07-14-2013, 10:26 AM
lemons12's Avatar
1.8 should easily be attainable with a good launch.
Old 07-14-2013, 10:49 AM
SWEET98SS's Avatar
I did a 1.87 on one run so its possible.
So i have a couple ideas to make it faster, let me know what you think. I would like to know which one is best for the money. I know when i shift that the tires are chirping so it is slipping, losing some ET.
- Install lower portion of FTRA, i took it off as the motor was getting hot with this one.(FREE)
- 28" tall tire, slick on 15" rim?
- same as above plus skinnies
- Chris1313 ram air?
- Strange S60 with different gear? dont think this will make it any faster but would be able to launch harder with a slick
- different intake manifold and TB
- SD tune?
Old 07-16-2013, 09:06 AM
SWEET98SS's Avatar
Looking for your opinions to the above.
Old 07-16-2013, 06:28 PM
Blackpanther99's Avatar
Definately get a Chris1313 and some bigger tires on the back. A fast intake will be good also while you are at it!
Old 07-16-2013, 06:52 PM
30th t/a's Avatar
Get a shift light ASAP! I thought I was good at hitting the gears, man I was wrong. On my first pass with the H/C setup I went 12.7@113, DA 2500. A few weeks later I went back to the track with a shift light and went 12.1@117. I installed 4:10s and went 11.9@120 on the 10 bolt, full street trim in good weather. I was running BFG Drs.
Old 07-16-2013, 08:45 PM
SWEET98SS's Avatar
I have 2 shift lights, the harlan and the aeroforce, shift light is set at 6600. If i set it at 6800 i hit the rev limiter.
I was also thinking of remove the following since its all free:
- rear seat
- front passenger seat
- spare tire and jack
- catback behind y pipe, less weight, hopefully more power
- disconnect front swaybar.
I know there is more i can get out of this setup without spending any more money. How much do you think I would gain with the above, .1 or .2?
Old 07-19-2013, 02:38 PM
handyandy496's Avatar
you might want to just remove the front bar and get some weight transfer going on.
Old 07-19-2013, 03:50 PM
NW Iowa WS6's Avatar
Remove front sway, awesome weight transfer and your front suspension will ride smoother than a caddy
Old 07-26-2013, 11:18 AM
stumprrp's Avatar
You def. gained MPH from the gears. 3.42's for a cammed car are terrible. Your improved 60' wouldnt do anything for MPH. Any time ive spun at the track my MPH was higher.
Old 08-13-2013, 11:44 AM
flattusmaximus78's Avatar
^ you should try 3.27's lol. Nice op!
Quick Reply: 3.42 to 4.10 gear results!
