New PB 9.27@148.8
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Went to Cordova this weekend to try and take advantage of the unseasonably cool weather. First pass off the trailer ran a new personal best with the car 9.278@148.85. Second pass I turned it up a little bit but was too aggressive with the launch RPM so I ended up putting it on the bumper and drifting towards the center line at the top end so I clicked it off early coasting to a 9.657@121.37.
The current setup is a 382ci LS6 with Patriot Stage 2 Heads, Bullet Cam, Vic JR intake, Accufab 4150 TB, Perimeter N2O plate with a 82 jet on a stock PCM with HP Tuners custom OS. Trans is a T56 that was faceplated by Tick Performance with a Spec stage 4+ clutch. Midwest Chassis & Performance did all off the chassis work including a full front suspension setup, 10pt cage, firewall and Lexan windshield, and a full rear suspension with a 9" rear 35 Spline Axles 3.89 Gears and a Strange S-Track.
![](http://img.photobucket.com/albums/v608/VDJHouse/WS6/Cordova_27-JUL-2013_Pass-1_zps1522f191.jpg)
![](http://img.photobucket.com/albums/v608/VDJHouse/WS6/1072392_10151867650463319_169896274_o_zpsf832bba9.jpg)
I would like to thank the following for all their help over the years
Olson Paint & Body
Tick Performance
Spec Clutch
Strange Engineering
Bullet Cams
Promax & Hilyard Performance
Mulvaine Motorsports
DRE & RLS Racing
Magic Photos
Olson Paint & Body
Tick Performance
Spec Clutch
Strange Engineering
Bullet Cams
DRE & RLS Racing
Magic Photos
Nice pass. Thanks for posting the time slip we have a local track but it is only 1000ft and I ran a 7.71 at the 1k and the rest of the slip are almost identical is nice to see the potential number I could run in the 1/4 mile. I have to make an effort to go.
Dam man congrats. That rollin out! I love to see a good gear banging 6speed video. Are you leaving on all of it?
I just stepped up to a 82n jet and first tests got it in the 5.60's 1/8 mile.
