1SC stripper build
1SC stripper build
Finally starting to come together. Approximatly 6 months ago I purchased a low mile 2002 1sc Camaro w/auto. Hopefully we can go out and have some fun racing locally this next summer.
Did alot of reading on the site and so far this is what I bought:
http://www.neweraperformanceparts.co...=NEPSShtCamF|0
Cam http://www.youtube.com/watch?v=N7nYRekEoiA
http://www.neweraperformanceparts.co...A=E&PKV=2013|0
Heads
http://www.neweraperformanceparts.co...&PKV=ytls1rr|0
Rocker arms
http://www.neweraperformanceparts.co...E&PKV=100221|0
Balancer
http://www.neweraperformanceparts.co...lanteTripleF|0
4000 converter
http://www.neweraperformanceparts.co...KV=LS19899-1|0
Headers
http://fuelinjectorconnection.com/sh...&productId=179
Injectors
Exhaust CME (Example shown)
UMI Kmember
AFCO double adjustable on all 4 corners
http://www.mandhtires.com/store.php?...on=show_detail
M/H tires
Wheels 2002 SS rims, fronts narrowed to 6" (weldcraft)
http://www.neweraperformanceparts.co...=E&PKV=70802|0
Subframe Connectors
Kenne Bell Boost-a-Pump
Prothane motor and trans mount
Tranny is in the shop gettiing upgraded.
https://ls1tech.com/forums/drag-raci...-c-delete.html
A/C delete
Vendors I delt with and have had excellent service with
New Era Performance
Midwest Chassis
Patriot Performance
Fuel Injector Connection
Heads
Rocker arms
Balancer
4000 converter
Headers
Injectors
UMI Kmember
M/H tires
Subframe Connectors
A/C delete
New Era Performance
Midwest Chassis
Patriot Performance
check the motor mounts if you have the offset on the wrong side?
assembled as per instuctions.
Looked at the stock tranny mount. The stud is offset toward the rear of the car that goes into the crossmember.
Made sure I had the correct mounts, engine, tranny and verified I put the motor mounts together correctly. Checks out.
So, I decided to modify my stock tranny crossmember to accept the Prothane tranny mount which does not fit well.
Here it is tacked and test fit. Goes on and off with ease.
Installed a SLP balancer which required a shorter belt to be used.
Installed the Afco rear coilover shocks, Midwest LCA and panhard bar. Next, saving for 9" from Midwest.
panhard bar
Preparing for ABS delete. Kit should arrive first part of next week.
Things left:
* Install KB boost-a-Pump
* Get PC680 battery
* Get 9"
* Install ABS delete
panhard bar
Things left:
* Get PC680 battery
* Get 9"
