Foward or reverse shift pattern better for drag racing?
6 & 8 Second Club
Depending on how fast you are. It is much easier to pull 2nd on accident, then push.
Also, if you every want an auto shifter, it's easier to push. The 1-2 shift gets pretty quick as you go faster.
More guys seem to like push when you try to sell a trans.
My last few have all been push & I like going from 2nd to neutral directly.
Race your car!
I have a rmvb in my car, th400 with a brake.
I'd actually like a fmvb with the brake though, as I feel the same way dragster does, I would like to be able to go from high gear to neutral directly.
When I put a glide in the car I am going to a forward manual valve body, but I think with a TH350/400 you have to have a reverse body with a transbrake, maybe that has changed, but I don't think so.
6 & 8 Second Club
Sorry, I should have said I love going from high to neutral directly.
Yes, all 3 of my cars use a glide or Lenco, depending on what I'm doing that season.
I should mention, I ran the pull style for years, and I fought changing. My buddies said shut up & do it.
After realizing how many times I accidentally pulled second, and realized how many times I was a little slow on the 1-2.
I got the push style and an electric shifter. I've loved it ever since.
I know guys bitch all the time that's not racing, your using a crutch ect ect.
All I can say is, I don't care, when you have a car that has 1.00's 60' and you've actually tried shifting that quick.
Then maybe I'll listen. I'm here to go rounds, the 1-2 shift is critical to being consistent.
6 & 8 Second Club
Exactly, if I went racing to screw around and just test & tune. I would get an 11 second 4 speed car.
I'm racing against guys with delay boxes, data recorders, timers, weather stations ect ect.
These guys run their number and cut .500's. I can't afford to screw around.
Good luck.
