What 60s with 15x8 wheel
I got 26x10.5x15 ET streets on Jegs stars but I am thinking I need more tire.
Would it be worth it to go to a 15x10 with 26x11.5 ET street or should I do suspension(which is stock right now)?
Best pass is:
1.62 - 60
11.37 @ 120 - 1/4
This was on a 125 hit and it chattered the tires pretty good out of the whole. I want to be able to hook with a 150 off the line to run some high 10s.
Best pass is:
1.62 - 60
11.37 @ 120 - 1/4
Best pass is:
1.62 - 60
11.37 @ 120 - 1/4
Best pass is:
1.62 - 60
11.37 @ 120 - 1/4
suspension,but on a good track my old setup 100% stock suspension with no front sway bar and 26-11.5-16 on stock z28 wheels, used to pull 1.47-1.50 60fts,3600tci stall,3.73,150hit, NEW set-up on a 28-10.5 on summit stars 15-8,my car goes 1.33-1.37 60fts..how old are your tires?how many street miles on them??
Saturday tnt. Sunlight and not many street cars made the track pretty decent. Did you ever spray yours?
1.54 but thats all i can get out of the tight conveter. Car never spins lca's, prokit up front, stock springs out back. 275/50/15 Et Street drag radials...11.04@123 mods in sig
the only problem i've had with that tire on a full weight car is the side walls don't seem to last very long, they were shot after a season. still plenty of tread and they'd get sticky, but even up to 18lbs of air i was almost taking the rims to the track in an 87 camaro with a 305 and 100 shot
My suspension is far from great but here it is...
Strange SA Struts (0-2 clicks from full loose depending on track)
Hypercoil 275lbs springs with the struts
Factory T/A
Non-adj LCA's
Non-adj Panhard Rod
LCA relocation brackets (1 in lower than factory ie. Middle hole)
CE 3 way shocks in the back (50/50 setting)
3600 Fuddle th350 converter
4.10 gear in my 7.5" 10 bolt
~3250lbs with me in it race weight
The car had 1.45's on motor in it easily with some fine tuning, but I only got to take the car out a few times this year and when I did I was bracket racing so I couldn't adjust on the car after the first pass.
Last year my car was practically identical to the times you posted up. This is the only changes I made to go from 1.60-64's to 1.47-50's.
-Replaced my 26x10.5 MT slick with a 28x10 Hoosier slick
-Replaced my 3.42 gear with a 4.10 gear
-Replaced my Bilstein shocks with CE 3-way drag shocks
-Replaced my Bilstein struts and factory spring with Strange SA drag shocks and a 275lbs spring
-Replaced my 165 metric front tire with a 25x4 Moroso Dragway Special (Which I think had the least amount of imapct on my 60's improving)
I had your exact same problem with practically an identical suspension setup, and above is exactly how I fixed it. I think my experience with correcting the same problems you are having will give you your best results. Many told me to try this or try that, but in the end, just swapping out what I did above made the difference I needed and was looking for.
Edit: I should include that I run your standard sidewall Hoosier slicks and I do not run tubes.
