Rear spring rubber isolaters removal?
Internet Mechanic
Dave,
Jack the car up, Put on stands
Removed Rear LCA bolt that attatches to the rear (one side at a time should be fine)
The Rear spring will be ready to remove. I sometimes use the Hyd. Jack under the Axle tube to help with removal/reinstall.
I do not know the exact size but you want to buy some rubber tubing, go to a place like Autozone/Pepboys and get some rubber fuel line. Take the spring with you to get the exact one.
Should need no more then 4-6 inches just to cover the top coil. (but buy enough for both sides)
JL stated to me years ago, should drop it about 1"
Race your car!
You don't even have to remove the control arm. Jack the car up, get the body on jackstands, support the rear with a jack, and unbolt the rear shocks, the rear will now hang lower then it would before.... lower the jack, pull the springs, pull the isolaters out, a piece if 3/8 heater hose over the first coil of the spring will quiet all the noise up perfect.
This will lower the back of the car about 3/4 to 7/8 of an inch depending on the car, measure the lip of the fender thru the center of the tire, and set the front about 3/4 of an inch lower then that. Car will need to be re-scaled, if you have a drag bar on you will have to unhook it and readjust, that type of thing. Getting it right with the measurments will get you in the right direction, but it will really need to be scaled (if it was before) to get it back where it was. If you didn't have it scaled, then just readjust the swaybar (if you can)
Make 1 motor pass just to make sure the car isn't taking off funny or anything when you go to the track just to be safe.
As a comparison, mine makes some noise - and it still has the isolators in place
Thought maybe I put the isolator back in at the wrong position / angle, tho it's probably nothing. Noise is very mild, going over slow bumps you can hear the compress-groan-creak.. similar to an old rocking chair.
These guys nailed it on the head but here's a writeup just to provide some more information:
https://ls1tech.com/forums/suspensio...d-writeup.html
Race your car!
You don't have to scale it Dave, just get both the front sides sitting even and start there, chances are it will be close.
I never had my car on a scale either, so I wouldn't worry about that, get it to leave level and strait and then scale it, sometimes cars need different stuff anyway.
https://ls1tech.com/forums/suspensio...ors-guide.html
check this one out. i did this mod about a month ago. best 5.00 bucks i've ever spent .
