Drag Racing Tech
My Stock Internal M6 buid thread...10's???
Old 08-19-2010, 09:00 PM
Magnet's Avatar
Default My Stock Internal M6 buid thread...10's???
The car is a 2001 MMM Z28 M6. I've owned the car for about a year and a half now and has gone a best of 12.18 @ 116.8 w/ 1.87 60' in +1183 DA according to drag times. The car is about 3230lbs in street trim with a full tank and 18in z06 replicas. Thats with all panels, radio, AC and all options...
Mods at time of track times:
Pacesetter LT's w/ TSP true duals
SLP UD Pulley
LID
SUX2BU ram-air
LCA relocation brackets
Bald 245 nittos
Added since track times:
Home ported TB
Harlan Shift lightZa
Plans before the cold weather:
MWC fab 9 w/ 4.30-4.56 and 28 or 29in stiff wall ET drags
PST Aluminum DS
ABS delete/ line lock
Adj drag shocks
2-step
Adj LCA's
Adj PHR
More weight removal!
[youtube]yrRh7jLFxMY[/youtube]
Old 08-20-2010, 01:02 AM
BlkBird2000's Avatar
Which drag wheels you have planned?
Old 08-20-2010, 06:25 AM
Magnet's Avatar
I have Greg weld front, and am looking at either racestar industries or prostar rears..
Old 08-20-2010, 07:25 AM
MikeG's Avatar
I think you're gonna have to tin can the hell out of it to make it. Which drag bar/torque arm setup you going with? What all will you be doing to save the weight?
Old 08-20-2010, 07:43 AM
blk/slvr02ss's Avatar
Let me know the next time u go to PBIR so i can come hang out & meet u.This winter should be fun out there .A bunch of guys did H/C/I/E to there car and we can go out there and show them up.
Old 08-20-2010, 08:08 AM
tee-boy's Avatar
Default 6 speed
keep us informed. 10's would be very impressive with a 6 speed.
Old 08-20-2010, 09:23 AM
ATwelveSec02Z28's Avatar
I see a few more things that you didnt list.....
biggest thing will be getting good air and a good track at the same time.
Old 08-20-2010, 10:47 AM
94Z28rag's Avatar
No way you'll do it with only the mods you have planned.
Old 08-20-2010, 11:24 AM
Magnet's Avatar
Probably 10s are definitely a lofty goal, this year I'm looking for low 11's hopefully..
Unfortunately I moves back home to fort myers, so chances are most of my racing will be at Bradenton.. Are you ever out there?
Old 08-20-2010, 11:31 AM
Magnet's Avatar
10's are my ultimate goal, low 11'a are probably more doable this season
Yea it's not happening without negative DA for sure.. What things am I missing? Any help is appreciated
I love me some haters! what else does your opinion think I need?
Old 08-20-2010, 11:49 AM
tee-boy's Avatar
just add the "Tornado" to you list, and 10's shouldn't be a problem - along with a 6200 rpm clutch hit off the line.
Old 08-20-2010, 01:45 PM
Internet Mechanic
BlackScreaminMachine's Avatar
All I am going to say is the times you will be either removing the trans to A) Rebuild or B) Fix the Clutch will be.....
Seven times.
Old 08-20-2010, 01:47 PM
tee-boy's Avatar
you just have to do it once.
Old 08-20-2010, 01:49 PM
Internet Mechanic
You always need to back the run up.
Old 08-20-2010, 03:19 PM
I write checks with my mouth that my ass can't cash
00blacka4's Avatar
i would add tubular k-member, lightweight battary, delete traction control and all that ****, cut fender metal if you havent already, manual rack....(already said you had skinnies that will help) drag brakes maybe if you can pull them off atleast for the front....maybe electric waterpump that picks up a few ponys....ur cars already running pretty strong it seems like what does it weigh ?
Old 08-20-2010, 03:25 PM
tee-boy's Avatar
117 is strong. I was running 115 stock internal in good air, but i have converter slip. Get that 60' down with less weight and more rpm off the line and you'll make it to 11's easy.
Old 08-20-2010, 06:40 PM
Magnet's Avatar
6200 off the line isn't out of the question...
Seven times.
Has stock tranny with a monster stage 3 clutch w/ flywheel and tick master with remote bleeder
Theres plenty I COULD do, but most of those things are out of the question money wise this season... I didn't list all my weight reduction either I pit my weight up top.. And that's street trim..
11s are a sure thing... How far is the question...
Old 08-20-2010, 07:08 PM
Internet Mechanic
Like I said, I see rebuilds in your future.
IF you want 10's you need to cut into the 1.4's 60 foots, which means off the limiter hits. Which then means you need to do a good amount of suspension work.
Old 08-20-2010, 07:16 PM
chrs1313's Avatar
I think it will take 122-123 mph from a m6...just because they are so hard to 60ft like an a4...
couple 100lbs of weight reduction, better traction 60fts and cold - da...going to need all three to make it work...best of luck man...
remember there is a reason why not many have done it before...it's going to take making everything perfect...I am doing that battle now going for 9s...
Old 08-20-2010, 07:31 PM
Magnet's Avatar
Thanks man, 10's are most likely out of the question this season, but your one of the few that knows its possible...
Quick Reply: My Stock Internal M6 buid thread...10's???
