how many guys are running a mid plate
like it says.....
who's running a front plate no mid with mounts...........and the mid plate seems like a pain in the ***,or am i just whining.i got this plate http://www.racecraft.com/index.php?m...oducts_id=1511 and im going to have to cut off the excess.just realized the headers need all the room on the side of the motor.
this guy has a pretty good idea.https://ls1tech.com/forums/drag-raci...-mounts-2.html
any body have any good ideas or pics.
7 Second Club
we cut the "ears" off the madman plate and hung it from the top.... we are now putting fender exhaust on the car and will probably put ears back on it and chop the top off.
always cutting and welding to make off the shelf parts fit.... thats building a racecar
Arch Engineering Integration (www.AEICNC.com)
It's good to see some of our products here... thanks!
We make custom motor plates for the 4th gen F-body, that require little or no trimming... and can cut any plate to order with any notch/scallop/bump/LOGO you might desire, and quickly. Our custom f-body front plate ties in the shock towers, and is available for SBC/BBC/LSx and coming soon LT1... you tell me where you want your crank centerline in relation to the frame rails (we know where the stock position is), approve your plate design, and it's cut and shipped in a matter of days.
Check the website, call with Qs... take advantage of our low prices! I'm always available to make a engineering solution for you, and have many LSx products.
Our newest mid-plate design is shown below, and is designed for maximum clearance in your 4th gen car... even motor/trans removal in one piece!
Many thanks to Tim, Justin, and Matt!
Bob Ette
314.435.3461
P.S: I subscribe to the rigid/rigid/flexible (front to rear) engine mounting scheme, with a sturdy longitudinal strut to limit the fore/aft inertial movement... take it easy on that trans case! Unless your chassis is absolutely rigid (don't fool yourself, really), a rigid trans mount can try to deflect your driveline when the chassis flexes.
Bob Ette
314.435.3461
We can design and fabricate the plates you need, xpndbl3! You'd be amazed how simple it is.... fill out the simple worksheet, review our design, make tweaks... We are working on 3rd gen specific plates, and can get you a solution very quickly. PM me with a contact e-mail and I'll send you the worksheet.
Bob Ette
314.435.3461
info@aeicnc.com
www.AEICNC.com
Bob Ette
314.435.3461
info@aeicnc.com
www.AEICNC.com
For anyone running our mid-plate. It's ok if you have to cut part of the mid plate off. Just so long as you are still able to mount the mid-plate to a solid point on the car, such as inner frame rails and or having a tube that is connected to the cage in some way. It's not that hard to install, and if anyone needs any help, just give me a call. 225-673-3533
