th 400/4000 stall - w/bolt-ons, 11.97 @112 n/a
went to the track finally with the new set-up.it WAS, m6, 4.10s, nittos, grotts, y-pipe, cat-back, free-mods.i made 1 pass.12.5@111 with 1.86 60ft(3520 race weight).it was an easy pass,then i tried to leave aggresivly and broke posi-unit and gears.so i decided to ditch the brutal launch of a m6 in favor for softer launch of an auto.i changed to 3.42s th400/trans-king 4000 stall.i lost 30hp on dyno,but tonite i ran 11.97/112 w/1.66 60ft.this was on nittos,1/2 tank of gas(for traction).about 3550 race weight.i still need a pulley, ls-6 intake, slicks/ .and i can remove about 100-150lbs by changing from 16in rims to some light weight rims,and some other weight removal.i think i can obtain some 11.6xs with these mods.so anyone curious about swapping to th400...it wont hurt.btw a th400 with 9in converter weighs within 5-10lbs of m6 with flywheel and clutch stuff.my raceweight increased only because i had 1/2 tank of gas. now,wheres my damn nitrous bottle??
I can shift faster than you.
Re: th 400/4000 stall - w/bolt-ons, 11.97 @112 n/a
Nice times Kip! I don't think we have to scan the car anymore since it is running so well. lol <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Congrats getting into 11's. Getting some lightweight wheels and tires should take around 80 pounds off your car. There are a lot of other things you can do to lightening it up. I bumped Colonels weight reduction list for ya. Check it out. It has a lot info on weights of different items.
If you are having problems with traction there is plenty of weigth that can be taken off the front. 20 pounds for front bumper supports, 15 pounds for front swaybar and brakets, 20 pounds for light weight battery and 35 pounds with a fiberglass hood. That adds up to close to 100 pounds off the front.
Nice times Kip! I know you are relieved to drive the car to the track and drive it home too <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
No more broken driveline <img border="0" alt="[bomb]" title="" src="graemlins/gr_bomb.gif" /> for you.
<img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
thanks,mike i just got back from laplace,at 70mph its 3500rpm,set cruise control and just went.it really wasnt that bad,a little noisy but not too bad.took 45 minutes.i ran one guy with m6 he ran 12.2@116 on nittos,he got me about 1 1/2 cars i spun bad(black top)then i ran jason he ran 12.17@111 last nite.i got him a little over a car.(i was able to leave ok this time).all in all the th400 swap isnt to bad.btw,that stealth lid fits like ***.ill talk with you more tommorow.
Kip once you get that car hooking you should be way into the 11's. Since you now have an A3 like crusty... does this make your car ghetto as well??? <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Steve...
Steve...
Glad to see another TH400 conversion going well...
I had some issues when I first got my TH400 setup...
I had Bilstein shocks all around, Firehawk rims in the front, and 26x8.5 et streets on the back...
I had a cam, headers, all bolt ons, 3.73 gear, leaving off a brake I could only get a 12.2@111...
Got Hals all around, switched to slicks/skinnies, lowered the stall, put heads on, with a new cam, and got the current times in the sig...
jd,better watch that tongue boy.going fri nite,but with..SLICKS,100 less lbs,opening the cut-out.hopeing for a 11.7,but ill settle for an .8.dont even have skinnys yet,or a pulley,or an ls6 intake,or that tubular k-member,and i dont need to lose weight to beat you.did i forget..i do have the gas on it.whats it run on gas.....i dont know!!!anyway,when you coming down!!
kip, find a pulley and I'll put it on for you this week. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
