Search is down: What is an Edelbrock Victor Jr worth over a Fast 90/90?
LS1TECH Sponsor
Going 13:1 compression, ETP 225 heads and T-Rex or larger cam on a forged 347. TH350, 12 bolt, 4.10 gears, full suspension. What would the Carb style intake with a 1000 CFM TB be worth over a ported Fast 90/90?
No Internet numbers please.
its still kinda new and really hasn't been fully tested (at least at the track)
I've done some digging and it appears to be a slight/modest gain over LSX at 6K and up. It also appears to lose some to the LSX under 4400.
its definately a neat piece
Interesting post.
https://ls1tech.com/forums/dynamometer-results-comparisons/311005-spm-hptuners-dyno-results.html
Keep in mind it was over a LS6 with stock TB. Probably would've seen 30 hp going to a Fast 90/90 (I gained 20 going LSX 90/90 over a LS6/ported stock TB)
One could also question the state of tune with the LS6 setup before too...
Race your car!
O.K., this is all fine on a stock CI motor. What about 400+ CI setup? I'm more intrested to see what it would do on say a 427 or more CI motor.
Guess what I'm trying to get at is I'm running a h/c setup now with a ported tb and a ls6 intake. I was thinking about going ot a fast 90/90 setup next summer... but I know that once I have my chassis working to it's max with the power I have now, I'm gonna start building a big CI motor.. and want whatever intake I am currnetly running to go to the next setup. I expect anything more then a 90/90 to lose somethign on the low end of a 346, but on a 427+ motor, (possibly even more) what would the results be like? I know that's gotta outflow a 90/90, just wondering how much.. and would it be worth it to hold off on a swap until I build the new motor, or do the swap to this style on a stock CI?
unless you are going for truly max effort high-revving 346 (serious head flow and large cam), it probably isn't right for you.
Remember too, getting it to fit in the confines of the engine bay and under the hood can be an issue.
LS1TECH Sponsor
It will be a max effort setup and I have a cowl hood for most of the clearance issues.
I am trying to figure out if the HP and speed increase is there.
Originally Posted by Steve Burger
At 13:1 compression and ETP225 heads with a T-Rex or larger cam it will not be a daily driver. This is being built with the drivability needs of: get from the staging lanes back to the trailer without killing the engine.
pulled this from another post, I don't think your going to find any better info than this at this point.
so on a 402 the vic was worth about 10rwhp over a LS2 intake from 5000 up and loses about 20rwtq down low
Originally Posted by 427
Ran one of our 402 crate engines with a LS2 intake and 90mm throttlebody. It had dyno headers with bullet mufflers. BS3 control.
Testing corrected to SAE OE standard. (same as Z06 505hp engine)
Dart head is 2.05 valve
Dart 225 w/LS2 intake--Dart head w/ Eldebrock intake
rpm--tq---hp---tq---hp
3000-428-244--387-221
3500-412-275--392-261
4000-465-354--444-338
4500-487-417--487-417
5000-490-467--501-476
5500-473-496--484-507
6000-446-510--454-519
6100-440-511--448-521
6200-433-512--443-523
6300-425-510--435-523
6400-417-508--426-520
We will do some mild port changes to see how they respond.
Dart head as tested: $1,630.50 retail,ready to install.
Kurt
Kurt
Race your car!
I'm not really planning on doing any max effort stock CI setup at this point. What I am tryting to determine is if the single plane intake is worth anything on a stock motor.. which it looks as if it's not really. I'm more intrested in what the results would be on a 427 or bigger motor with heads and cam enough to really feed it, what would the gains vs. losses be vs a ported 90/90 setup? When I start building the new motor.. it will be a min of 427 CI, and should I go for the world block it will be alot more then that... and it will have max compression and whatnot that I can get away with on pump gas, and the biggest baddest heads I can get, as well as plenty of cam to feed it. 1 7/8 merge collector headers will go on, will be a pretty max effort pump gas motor when I'm done. A VFN 2 inch ws6 cowl hood will be making it's way to my car eventually as well, so hood clearance shouldn't be an issue... only thing I will stop at is cutting the actual metal in the cowl of the car itself.... and I do believe that with an elbow that is slightly milled some, and a little milling off the top of the intake, (say .100 max off both together) there will be no cowl clearance issues, only with the factory hood, which won't be a problem.
I was thinking it would be a nice addition to toss on my head/cam setup for a while, but if what I'm seeing is correct, there's no point to it on my ls6 headed small cammed setup that I'm running now. I'm not even sure what I'm making for power at this point.. was 403 before the heads went on.. waiting to retune it in the spring when it warms up some. Thinking it's in the 440 rwhp range.. knowing who's car the heads came off that I'm now running, it should be aorund there.
If anyone has tested the intake with an elbow on a 427 ci + motor, I'd be intrested to see that.
if you want to run any kind of "standard" elbow, metal has to be cut.
this car had all the milling you are talking about but that doesn't fix the fact that the motor sits under the cowl
sure some companies make sheetmetal elbows that fit under the cowl, but I kinda question what that does to their flow potential
That is our intake setup, and as Fireball posted, it wont clear without issues. I had the GMPP intake milled .25 and the elbow based milled .3 and you can see we still had to trim the cowl area. We are using a Glasstek pin-on hood and it just barely rubs, and that is with the top of the elbow was milled as well.
FYI: No need to question the before and after tune, as Ken@HPTuners did the work. I mearly tweaked it at the track.
