Drag Racing Tech
racing without an engine belt
Old 11-19-2006, 09:23 AM
hesham's Avatar
Default racing without an engine belt
now if i have an electrec water pump and my battery was fully charged can i go to the track without an engine belt? the resone is that i can free the load form the cranck
Old 11-19-2006, 10:15 AM
CTSmechanic's Avatar
If you seriously have all the stuff listed in your sig done to your car 5 hp isnt going to matter Id start with some suspension or tire.... just a thought....
Old 11-19-2006, 10:29 AM
hesham's Avatar
i alrady have susp. and i am using neto 555 redials but in at the track i will be using full slicks
Old 11-19-2006, 10:30 AM
novass72's Avatar
a fully charged battery has a reserve capacity of 100 minutes if you were not using any accessories (lights, a/c, etc.)
only if the track is close!
Old 11-19-2006, 01:32 PM
99SS-T's Avatar
I wouldnt do it. It may free a couple of HP up but when u dont have the alt runnin the car gets ALOT less voltage. I get about 14.0 volts at cruise speed and 13.5 at idle. When the altenator is disconnected i get 11.8 immeaditly and drops off pretty fast. U might get a few minutes outta it at a descent pace but with a big *** pump and all the other electronics that u have ull be draining power REALYL fast. Im not sayin that u will be outta juice before the tracks end im jsut sayin that u wont get the necessary voltage to teh things that need them and u can end up blowin the motor as teh pumps wont pump enough fuel. GL man
John
Old 11-19-2006, 01:36 PM
67Ranger's Avatar
why not take the belt off at the track, and take a battery charger for between runs?
Old 11-19-2006, 04:00 PM
hesham's Avatar
now thats what am talking about
but with my msd coils, twin welbro intank, aeromutive pro s. inline, boost cooler, flix 4600 cfm fans, and nitrous acc. will the volt. be enough for 1/4 mile?
Old 11-19-2006, 05:23 PM
Fade2blk500's Avatar
It wouldn't make enough difference to matter, so I wouldnt bother with it personally.
Old 11-19-2006, 05:50 PM
Power steering would be nice... not to mention make it easer to drive esp if you got out of shape...
Old 11-19-2006, 06:10 PM
2000LS1TA's Avatar
Old 11-19-2006, 10:03 PM
Adrenaline_Z's Avatar
You're crazy to try it. You need water flow to remove hot spots throughout
the engine.
By the time you line up, burn out, stage, and make the pass, the engine will
be over temperature, and possibly damaged. It's also a good way to induce
detonation.
Old 11-20-2006, 12:19 AM
HD1911's Avatar
the engine.
detonation.
Old 11-20-2006, 01:21 AM
GOaT Cheese's Avatar
I have a toggle switch that kills the field windings on the alternator. Flip the switch and it just free wheels, then on the return road, flip it back, it works great.
Old 11-20-2006, 01:38 AM
2002_Z28_Six_Speed's Avatar
It doesn't matter if the electronics are getting 14 volts of 12 in this case. They were designed for 12 volts.
The amperage is what is pushing the power in this case. Don't worry about your ignition system.
However, I would think that the battery weights more than the alternator. Why not try keeping the alternator and putting in the battery just to start it?
Old 11-20-2006, 01:53 AM
hesham's Avatar
so this idea is not worth it?
Old 11-20-2006, 07:25 AM
Originally Posted by HD1911
Good one, you got me. Not sure how I missed electric water pump on the
first line.
Old 11-20-2006, 08:18 AM
SlickVert's Avatar
Do you see any ET or MPH difference with the Alt on or off?
Old 11-20-2006, 08:50 AM
((((((Administrator))))))
CRAGER's Avatar
first line.
I missed the electric water pump thing as well. DOH!
But seriously, trying to get what maybe 5hp from that? Look for it somewhere else man. You have 2 power adder's, up the boost and/or the pill for the gas.
Peace,
Craig.
Old 11-20-2006, 08:53 AM
MrDude_1's Avatar
if you're pushing a intank pump hard, it matters.
if you're trying to light off a forced induction or large nitrous car, it matters.
just something to think about....
Old 11-20-2006, 12:01 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
first line.
My guess is that you had trouble discerning what the hell he was trying to say, examples:
Not trying to be the grammar police because I know I make mistakes, but holy ****.
Question, by boost cooler do you meen intercooler? Is it an air to air or air to water. Just wondering because there's no way an a2a intercooler draws voltage.
