Drag Racing Tech
New Centerline Convo Pro 15x9 wheels-Pics
Old 03-03-2007, 08:19 PM
Moderator
JNorris's Avatar
Default New Centerline Convo Pro 15x9 wheels-Pics
Here are some pictures of the Centerline’s new 15x9 with 6.5”bs Convo Pro wheels with 275x50x15 tires on them.
As you all might know 15x7.5 5”bs and the 15.8.5 5”bs Convo Pro wheels do not require grinding of the brake calipers to fit our cars. The only small problems with these two choices are tire size limitations of a 7.5” wheel and the 15x8.5 wheels stick out a little.
I really like the look of the Convo Pro wheel and I think the 15x9 wheels look great on the car. The only problem is the 6.5” backspace does require some grinding of the brake calipers to fit our cars.
The picture at the link below compares the fit of the 7.5”, 8.5”, and the 9” Convo Pro wheels.
http://www.wheels.ls1tech.com/galler...&g2_itemId=755
All the pictures can be seen here:
http://www.wheels.ls1tech.com/galler...=184&g2_page=2
The caliper grinding can be seen here:
http://www.wheels.ls1tech.com/galler...=193&g2_page=2
Old 03-03-2007, 09:01 PM
6techniques's Avatar
look really nice on a white car...why does centerlines backspacing seem so different compared to weld's? Do you have to run a deeper bs'ing in order to keep the wheels from sticking out to far?
Old 03-03-2007, 09:02 PM
DrkPhx's Avatar
Looks nice. Did you happen to weigh each wheel/tire combo?
Old 03-03-2007, 09:35 PM
Moderator
JNorris's Avatar
Whether the wheels are Weld or Centerline the magic number for backspace is wheel width (9”) minus 2.5 to get backspace amount. This is not an absolute but it is close. The wheel sticks out of the fender a little if it has more than 2.5” of “front space”.
Weld 15x8 have 5.5”bs so 8-2.5 = 5.5
Weld 15x10 have 7.5”bs so 10-2.5 = 7.5
Centerline 15x7.5 have 5”bs 7.5-2.5 = 5
Centerline 15x9 have 6.5”bs 9-2.5 = 6.5
Centerline 15x8.5 have 5”bs 8.5-5 = 3.5 – These wheels stick out a little
The rear wheels and tires weigh 42.5lbs each. The wheel alone weighs 12.5lbs on the bathroom scale. The front wheels and tires weigh ~24lbs each.
John
Old 03-03-2007, 10:43 PM
gator's 99TA's Avatar
looks much better IMO.
Old 03-03-2007, 10:48 PM
Retired Street Racer
Matt D's Avatar
What's the part number? I don't see it on Summit or Jegs...
Old 03-03-2007, 10:56 PM
5_02ls1's Avatar
very nice a+ on appearence
Old 03-04-2007, 12:14 AM
sixvi6-camaro's Avatar
Damn.. those look good.. Edit.. got the size form the other thread on the wheel stire forum..
"The front wheels are 15x4 with 1.75”bs and 165R15 tires."
any grinding on the fronts to get them to fit?
Old 03-04-2007, 09:12 AM
Moderator
JNorris's Avatar
The Centerline part number is 005907547
Old 03-04-2007, 09:13 AM
Moderator
JNorris's Avatar
No grinding needed for the front wheels to fit.
Old 03-04-2007, 10:34 AM
mike#9's Avatar
What is the biggest rubber out back that you could fit comfortably on these rims?
Car looks great!
Old 03-04-2007, 03:55 PM
chrs1313's Avatar
this is the exact combo i am getting already got the fronts...does any sponsors do a group purchase for these rears...what is the cheapest place to get them they are charging 319 on summit which is crazy...anyone know
Old 03-04-2007, 04:54 PM
JunkyardZ's Avatar
Looks great on white, maybe I need a set. lol
I've been waiting on centerline to make a convo pro fits "right"
Old 03-06-2007, 06:02 PM
Matt D's Avatar
Thanks John. $320 a piece & I have to grind the rear calipers??? Damn!! I might just stick with the 15x7.5s out back with a MT 275/50/15 drag radial.
Old 03-06-2007, 09:25 PM
NHRAFORMULA00's Avatar
Alunimum has gone sky high in the last year!!
Old 03-06-2007, 09:55 PM
fastgm_silver02ws6's Avatar
looks good!
Old 03-07-2007, 01:43 PM
chrs1313's Avatar
how well is that going to fit the 275/50.15 becuase that is the size that i was wanting to run on the 9in rim...how is that going to fit/look on the 7.5...dunno what to do right now 7.5 or 9, i want them to fit nice in the wheel wells so 8.5 is out...
Old 03-07-2007, 01:54 PM
Matt D's Avatar
I had the 275/50/15 on an 8 in Prostar with no problem. This is taken right off of their site: "Acceptable practice for rim width plus or minus 1.'' Their measuring rim for # 3753R was 8.5". If you look at the BFGs in 275/50/15, they say their minimum is 7.5" too. So 7.5" should work fine on the MT as well.
Old 03-09-2007, 07:07 PM
GeArBaNgEr56's Avatar
Want to sell your 7.5s?
Old 03-09-2007, 08:49 PM
z-ya's Avatar
They make them in convo et,and warrior styles also now in 15x9 6.5 backspace if that
tickles your fancy.If you run 15x4 fronts with 2 5/16 backspace they will tuck a little
more but need some grinding of the caliper.
Quick Reply: New Centerline Convo Pro 15x9 wheels-Pics
