Drag Racing Tech
FIRST TIME TO THE TRACK
Old 05-23-2003, 11:27 AM
Breakfast Fanatic
Pewter02TA's Avatar
Default FIRST TIME TO THE TRACK
this is my first time to run at the track
bone stock trans am on GSC
anything i should do to prep the car
what about tire pressure
-Aaron
Old 05-23-2003, 01:20 PM
h53speed's Avatar
Default Re: FIRST TIME TO THE TRACK
Yeah pull your back seats, spare tire and jack. Emptying your windshield wiper resevoir is good for a few pounds. With my stock tires I started out at 28 psi and I think when I started cutting 1.9 60's I was running around 24-26.
Good Luck.
-Wes
Old 05-25-2003, 12:26 PM
Kent1's Avatar
Get you an ASAP Pulley and port and polished TB. Recommend some drag radials such as Nitto's, adjustable shocks front and back just for starters. Happy motoring.
Old 05-25-2003, 06:49 PM
Administrator
unit213's Avatar
He means an ASP pulley. Porting/polishing the TB is a good idea. You'll pick up a few ponies there. Adjustable shocks are completely unnecessary until you get into the big horsepower range. I'm running mid 11's on complete stock suspension and street tires. As for tire pressure, air up the fronts to about 40psi and drop the rears in 2lb increments until you "hook". I found that my 16" GSC's hooked best at 23-24 cold psi. That's about 25-26 when they are hot. Drive around the water box. Do NOT go through it with street radials. Do a 2-3 second burnout to clean off the tires only. Don't bring the rpms up too much or your 60' will suffer. Powershift, hold on, and have fun!
Old 05-25-2003, 06:51 PM
Administrator
unit213's Avatar
Oh yeah, defintely pull your spare tire and jack. A 1/4 tank of gas is cool, but I've found that 3/4 tank helps me hook better due to extra weight over the rear wheels. It's a tough trade off...an extra 150lbs for some traction. Draining the washer fluid was a good tip. Remove the front sway bar too if you want to get a little more hardcore. It's a piece of cake.
Old 05-26-2003, 01:22 AM
Breakfast Fanatic
Pewter02TA's Avatar
well i ran a best of 13.2 with everything stock but a lid
im very pleased
Old 05-26-2003, 09:03 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
good times for only that mod! keep at it!
Derek
Old 05-26-2003, 04:57 PM
DONAIMIAN's Avatar
Yea iI still cant belive you pulled it off. All this talk about how you wouldnt break into the 13's. And your still new at the whole M6 thing too. With more seat time im sure you can break into the 12's with the car the way it is now. Its a big step up from when you raced your bro and kept hitting the brake peadal on every shift. With a time like that, I will no longer bring that up anymore
Old 05-27-2003, 12:27 PM
redsscamaroboy's Avatar
Good job,Those m6's are a lot harder to get an et out of the a4's.
My a4 stock ran a best of 13.24@104.85 with a 1.99 60ft.
Good job!! Nice .
Dave
