Frankenstein Heads Cam LS3 Dyno numbers inside.
Old 04-26-2016, 02:01 PM
FD3SLS1's Avatar
Default Frankenstein Heads Cam LS3 Dyno numbers inside.
This past weekend I got around to swapping in my LS3 engine into my 05 CTS-V. I got it dyno tuned yesterday and needless to say I'm impressed with the numbers. Frankenstein for the WIN!!
460 RWHP / 408 RWTQ.....on a Mustang Dyno which dynos about 15% lower than a dynojet. So the DynoJet Corrected Numbers are 529 RWHP/ 469 RWTQ. This run was done with the car at 215f, should be a little higher on a cooler dyno run.
Tuning was done by Travis Lane at Carolina Chassis Dyno in Lexington, SC
Stock LS3 shortblock
Stage 1 ported LS3 Heads by Frankenstein racing with dual valve spring and Ti Retainers 11.0:1 compression
Ported LS3 Intake by Frankenstein racing
Ported LS2 Throttle Body by Frankenstein racing
Frankenstein racing spec cam motion cam 233 dur .630 lift intake 246 dur .605 lift exhaust 113 +3 LSA Hyd Roller
LS3 Injectors
SLP 25% Underdrive Pulley
Melling High Pressure Oil Pump
Comp Cam Rocker Trunion Upgrade
LS7 Lifter
ARP Head Bolts
Maximizer (ebay) headers - no cats
Magnaflow catback
Volant Cold air intake
Video - open headers
Video - with exhaust
Old 04-26-2016, 10:25 PM
DavidBoren's Avatar
Very solid, sir. Always loved the V1's. Had a six cylinder '05 CTS for a minute. Really liked the platform and the look. You seem to have a really solid start.
Old 04-27-2016, 02:30 AM
DietCoke's Avatar
Originally Posted by FD3SLS1
So the DynoJet Corrected Numbers are 529 RWHP/ 469 RWTQ. ]
No.
Old 04-27-2016, 07:08 AM
FD3SLS1's Avatar
Well I have read that there is anywhere from 10-20% difference between a mustang dyno and dynojet so I went in the middle at 15%. Once I get some more miles on the engine we are going to give it some more RPM and play with the timing some more and see if we can squeeze some more power out of it.
The 460 RWHP came at 6250 RPM and it was still climbing.
Originally Posted by DietCoke
No.
Old 04-27-2016, 09:23 AM
RollingDumpster's Avatar
What was your final chamber size on the heads? Most vendors seem to limit the chambers to a minimum of 65cc but I have read folks going down to 58cc.
Old 04-27-2016, 11:07 AM
FD3SLS1's Avatar
They are 65cc
Old 04-27-2016, 04:20 PM
1989GTA's Avatar
I have my car tuned on a Mustang dyno and he says his dyno runs about 4% lower than the Dynojet down the street. My car is in the low 500rwhp range so if I went on the local Dynojet it might read 20 more rwhp. I will just say dynos are different and it will be hard to put a number on it. Some are happy dynos and some are stingy with a whole lot in between. The track will tell.
Old 04-28-2016, 08:34 AM
LS1Tech Sponsor
hellbents10's Avatar
Nice results never seen a Mustang dyno that is calibrated correctly differ much from a Dynojet. Around here they are about the same.
Old 04-29-2016, 03:59 AM
1970camaroRS's Avatar
Well I have read
Don't believe everything that you read.
Old 05-01-2016, 01:43 AM
KW Baraka's Avatar
.......460 RWHP / 408 RWTQ.....on a Mustang Dyno which dynos about 15% lower than a dynojet. So the DynoJet Corrected Numbers are 529 RWHP/ 469 RWTQ......
No......
I would have to agree.
The Mustang dyno numbers you got are nice!
But if you want to know what your dynojet numbers are.....then run it on a dynojet!
Jus' sayin'.
KW
Old 05-02-2016, 09:58 AM
thunderstruck507's Avatar
Jus' sayin'.
KW
Correct. There is no magic formula to convert one calculated number to another calculated number due to the vast variables between them.
I've seen Mustangs read higher than Dynojets in some cases.
Old 05-02-2016, 08:46 PM
gnx7's Avatar
The real measurement is how many MPH it gains at the strip. Report back after that.
Old 05-05-2016, 03:05 PM
MASS seller approved
low2001gmc's Avatar
Nice set up...
Quick Reply: Frankenstein Heads Cam LS3 Dyno numbers inside.
