These numbers look right?
Old 11-25-2004, 08:17 PM
Cokeroker's Avatar
Default These numbers look right?
MODS in SIG. I also know that I lose a lot through the A4 w/ 3500 stall and 3.73s...
386hp / 364tq (A/F was about 12.9 all the way across)
on the 125 shot: 479hp / 465tq (went dangerously lean at 17+, so the high flow fuel pump is the next purchase before she gets sprayed again)
coker
Old 11-25-2004, 08:34 PM
99BackNBlackZ28's Avatar
I would think even w/an a4, you should still be making more power with that cam. IMO.
Old 11-25-2004, 08:36 PM
LSs1Power's Avatar
Those numbers looks good for an Auto with 3500 stall. 17 AF with NOS is a big NO NO. Are u running a dry system? Why dont u just get a Wet system and put a larger fuel pill. That should fix your probelm. Good luck.
Old 11-25-2004, 08:56 PM
BlueSix's Avatar
Hopefully those are unlocked numbers. If they are then you are doing very well.
Old 11-25-2004, 09:00 PM
Cokeroker's Avatar
wet kit on the NO2.... debated the larger fuel pill to try to compensate, but was not sure if that was gonna do the trick or not.
i am not sure how to tell on the dyno graph if it is with the converter locked or unlocked. nothing special was done to lock/unlock it if that helps
coker
dyno sheet is attached
blue = N/A
red = NO2
Old 11-26-2004, 12:38 AM
Cokeroker's Avatar
t t t for me
anyone... please advise
coker
Old 11-26-2004, 06:17 PM
Tim 98z's Avatar
OMG ADD SOME FUEL!! You going to blow that thing up.
Old 11-26-2004, 09:46 PM
Cokeroker's Avatar
found out that the fuel solenoid on the kit is bad so replacing it..
