LME 408/ET 245cc head results....
Old 04-05-2006, 09:38 AM
gtodoug's Avatar
Default LME 408/ET 245cc head results....
Well I've been dialing in the setup on the street when I can with my hectic work schedule. For those of you who don't know the setup it's a:
LME 408ci
11.94:1 comp
254/260 .660/.643 114 LSA cam
Kooks 1 7/8" headers
Corsa single 3" exhaust
ET 245cc heads
This tune is on 93octane pump gas. So far I'm only able to run a max of 17* of timing on the street. I attribute part of that to the CR and 93 octane and the other part to the poor exhaust I'm running. I dropped the exhaust on the dyno and it was worth 18whp and 22lb ft of tq! So needless to say my SW dual 3" is in transit. I didn't want to run cutouts, so a full exhaust is in the works. The pulls below are with the exhaust attached and with about 500 miles on the motor.
The car is tuned in open loop SD using HP tuners 1bar SD software. These pulls were made through my single driveshaft/3.91 gears/ and 18" wheels and tires as well. I left the a/f very conservative at 12.1 down low and 12.6 up top. Should be some more power left in there of leaning it out as well. I think that's why the tq is so weak down low. I'll get it squared away though.
I've got a couple tricks up my sleeve yet, hence why I'm calling it the "preliminary results"
Here is the very first/last pull after some timing/fuel tweaking.
Video of car on the dyno:
http://media.putfile.com/408-dyno-pull
Old 04-05-2006, 10:37 AM
7 Second Club
Phil99vette's Avatar
interesting...sent PM
Old 04-05-2006, 10:48 AM
LS1 Tech Administrator
Patrick G's Avatar
For preliminary dyno numbers, they're pretty darn strong. Hopefully with more exhaust development and further tuning, you'll have the numbers up there with your earlier power predictions. Gotta love these cars!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 04-05-2006, 10:49 AM
bad95killer's Avatar
Damn stout #'s buddy considering ya running 12.1 to 12.6 A/F ratio more tweaking to ensure the 550rwhp
Congrats man
peace
Old 04-05-2006, 11:58 AM
Orange Peel's Avatar
NICE numbers dude! I'm hoping for 500rwhp with my Combination Motorsports 402, that's got to be a blast to drive, tons of torque down low, poor tires
Old 04-05-2006, 01:06 PM
ls1408cp's Avatar
is 530 with the exhaust dropped
Old 04-05-2006, 01:39 PM
LSs1Power's Avatar
Very nice.
Old 04-05-2006, 03:11 PM
cantdrv65's Avatar
Post
Excellent numbers for the tune being as off as it appears....
Old 04-05-2006, 05:22 PM
gtodoug's Avatar
No 530 is not with the exhaust dropped
Old 04-05-2006, 05:23 PM
gtodoug's Avatar
I think the tq is way low in comparison to what I've seen some other 408's put down. I was hoping to hit that 515-525rwtq mark. After the first pull, I realized that was a pipe dream.
dougie
Old 04-05-2006, 05:33 PM
11 Bravo's Avatar
Not bad. If the ET heads are everything they claim to be, you should have alot more left in it. How is that cam on the street, BTW?
Old 04-05-2006, 05:40 PM
niphilli's Avatar
What intake manifold?
Old 04-05-2006, 05:42 PM
Patrick G's Avatar
dougie
Yeah, the standard for good torque under the curve seems to be 1.25 lb ft of rear wheel torque per cubic inch. 510 would be that number on a 408. Anything above that is just outstanding. Once you get the exhaust and tune sorted, I would expect to see the mid-range torque pick up some although I feel that your cam is mis-matched for your combo. The same cam on a 108 or 110LSA would give you MUCH more area under the curve. You appear to have a classic case of low dynamic compression and too late of an intake valve closing point for your combo (FAST 90/90).
Old 04-05-2006, 06:38 PM
prostock_bigblock's Avatar
why 114 LSA?
Old 04-05-2006, 07:02 PM
gtodoug's Avatar
I don't know. I tried to keep it streetable and was afraid that the cam would be too much for the street. EDC made the cam. I kept stressing to him I wanted the cam to be driveable. It's more driveable than you think now, but is very very loud. Maybe i'll switch down the road.
Dougie
Old 04-05-2006, 07:04 PM
beardWS6's Avatar
Nice GTO! I was hoping for differant numbers also. But this ****** runs its AS-off!! Will be at the track in 2 weeks. Then will see what shes got!! Great numbers!!!
Old 04-05-2006, 08:02 PM
gtodoug's Avatar
Patrick, when I initially had this cam ground. I had spec'd out a different set of heads, was using 2.5" duals, and my entire setup changed due to me having too much time on my damn hands. I built the setup around the motor and heads and stuck the cam in that I had ED spec out before I had the motor built.
Old 04-05-2006, 08:05 PM
kumar75150's Avatar
Honestly, this makes me want to hold of on purchasing ETs for now. I know you will probably pick up more power but I thought 550 would be a breeze with a big cam.
Either way 530-540 is gonna run its *** off. Im anxious to see what mine will make with LS6 heads and the new cam.
Old 04-05-2006, 08:17 PM
gtodoug's Avatar
Well, next mod for me is a possible cam change, and ITB(individual throttle body) manifold from Harrop. If it really adds that much hp. I just want someone else to go first.
Keep in mind guys I'm not running much timing in this setup either. My timing map looks like this:
2800-17*
3200-17*
3600-17*
4000-16.5*
4400-16.5*
4800-16.5*
5200-15.5*
5600-14.5*
6000-15.0*
6400-15.0*
Anything more than that, I get some KR induced. Not much, but .1-.2*. So I backed off a couple * to aid in fighting the detonation. I'm going to try some torco and see if it makes a difference.
dougie
Old 04-05-2006, 08:32 PM
kumar75150's Avatar
with that big a cam, im surprised you are getting knock at 11.9:1 compression
doesnt sound right
Quick Reply: LME 408/ET 245cc head results....
