5.3L S-10 Swap goes 449HP 456TQ Spining on the rollers.
Old 08-23-2006, 09:32 PM
Black X's Avatar
Default 5.3L S-10 Swap goes 449HP 456TQ Spinning on the rollers.
Took the truck to the dyno today.
Click here to see Video
Naturally Aspirated #'s
325RWHP 327RWTQ
150 Jets
449RWHP 456RWTQ
Truck was spinning pretty bad. You can see in the video out the back of the shop everything disappears....
Was hoping for a little more on the bottle. The N/A numbers are awesome, I could not be happier.
MODS:
2001 5.3L engine, BBK SSI Intake Manifold and 80MM throttle body,Comp cams 216/220 .525/.532 114LSA, Comp Cams 918's, Comp Cams Hardened push tubes, Custom 3.5" cold air intake, Sanderson 1-5/8" primary ceramic coated short tube headers,Custom 2.5" Y-pipe into single 3.5" through dynomax bullet and flowmaster 40 series, MSD wires, NGK TR6 plugs, ASP Underdrive pullies, ARP Rod Bolts, Electric fans, B&M Hammer Shifter, YANK SS3600 Stall converter, Trans-go HD-2 Shift kit, Corvette Servo, 3.73's, Zexel Torsen Differential,TA Performance Girdle, Competition engineering Slide-A-Links, Mickey Thompson 255/50/16 Drag radials.
Old 08-23-2006, 09:43 PM
Sport Side's Avatar
Sweet truck... Any pictures of engine bay, exterior, exc...
Old 08-23-2006, 09:48 PM
KAOS's Avatar
weight? that thing is sick
Old 08-23-2006, 10:08 PM
Black X's Avatar
Old 08-23-2006, 10:10 PM
Black X's Avatar
3850 With driver
Old 08-23-2006, 10:12 PM
ArcticZ28's Avatar
Badass truck but how in the hell are you gonna put that to the ground?? My buddy's got an S-10 with only an old small block and he had to put weights on the rear leafs to get any traction whatsoever.
Old 08-23-2006, 11:02 PM
Black X's Avatar
Old 08-24-2006, 05:50 PM
slimcracka's Avatar
was that with the converter locked or unlocked...the N\A numbers seem a lil low too..but then again it is and auto and im sure its a blast to drive..looks good too!
Old 08-24-2006, 06:09 PM
Black X's Avatar
It's just a 5.3L Cam only.... those are very respectable N/A #'s for a 5.3L
N/A Locked
N20 Unlocked
Old 08-27-2006, 04:22 PM
cws T/A's Avatar
Thumbs up
Nice install Engine looks as though it came from the factory that way
Old 08-28-2006, 01:08 AM
Bo White's Avatar
Like the Centerline wheels too . The guy that Sanderson used for the prototype on the ls1 swap headers lives here in a town close to me, he doesnt own the truck anymore but it was an extended cab and it would tote the mail
Old 08-28-2006, 01:11 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That's deffinetly a sweet truck.
Old 08-28-2006, 06:06 PM
TJ
TJ's Avatar
nice #'s.
why was it spinning on the dyno?
