Dyno sheet 233/239 92mm Ported.
Old 06-07-2008, 11:21 PM
coolformula's Avatar
Smile Dyno sheet 233/239 92mm Ported.
Hey guys I have had my car for 2 years and finally got it dynoed tuned. Numbers are about what I was thinking(crappy 99 heads lol) I had the LS6+Ported TB but we didn't dyno run it until after my new FAST. Very similar set up in GM hightech went from 390 with the ls6 to 412 with the fast. So I think I gained around 17 or so with the fast. I know I know its not the best cam car only and its a big cam with no low end, but I enjoy it and it does pull nicley up top. I wanted to wait on the street warrior, but I just didn't want to wait any longer they kept pushing it back, then when it comes out its going to take a while for any bugs and it to be proven to be good. I'm a little suprised it didn't pull better past 6k.Thanks for looking
233/239
ported 92mm
90 or 92 TB
85mm SLP
85mm Fast toys
True Duals
Pace Setters
U/D pulley
28 pound 2002 injectors
ported oil pump
Stock 853 heads
0z700 clutch and steel flywheel
Old 06-08-2008, 08:17 AM
LS1 SPEED's Avatar
nice results
Old 06-08-2008, 03:24 PM
cbra-klla's Avatar
id be happy with those
Old 06-08-2008, 03:34 PM
SMOKNSS's Avatar
Hell ya..... I'd be happy... with a graph like that I 'd say throw some gear at her and don't worry about the area below 3K..... 4.10s are NICE
Old 06-08-2008, 03:41 PM
allngn_c5's Avatar
Low end leaves a little to be desired. You have the same rwtq at 4000 as I do at 2800(same displacement), and my cam is a good bit larger. Don't think I am being negative about your setup bro. The torque curve is super flat and I bet she pulls hard. Someone mentioned a UD pully is a good mod for your car, I'd say definately. Could add another 10 rwhp 6 rwtq. Not a ton, but every bit counts. Just wait until you put a set of MILLED heads on there. Bumping up your compression will bring up that torque to a more desired level. Good luck with future modding.
Old 06-08-2008, 03:49 PM
Mikes96z's Avatar
What LSA is that cam on? I have the same one.
Old 06-08-2008, 04:11 PM
I have a underdrive pulley. I do not know the LSA lol. Thanks for all the comments. Not the best setup but not the worst either. I"m pretty happy with it...
Old 06-08-2008, 04:20 PM
allngn_c5's Avatar
Sorry missed that. I see now that you do have the pully. Anyways bro, as long as you are happy, that is all that really matters.
Old 06-08-2008, 06:41 PM
firefighter813x's Avatar
Your over 400whp. That's all that matters! lol. That's why I won't dyno mine, because I know a stalled A4 I wont be near 400.
Old 06-09-2008, 08:24 AM
LS1C5Vette's Avatar
Yo, I have that cam with 853 heads and put the numbers sown in my sig (no fast), our heads SUCK, once we get heads expect another 40 RWHP
Old 06-09-2008, 01:40 PM
Kingc8r's Avatar
Nice numbers.
Firefighter, my buddy got down on himself because his untuned SS4000 with LS6 intake, LTs, O/R Y, SLP dual/dual, SLP lid A4 only did 303 to the rear wheels. I told him, run it at the track and you'll be happy
Old 06-09-2008, 02:06 PM
gnx7's Avatar
With ported heads that cam pulls to 7K easy.
I had '99 shortblock, Katech rod bolts, ported LS6 oil pump, LS2 Tchain, same cam, AFR205's milled, GM metal gaskets, LS6 intake, ported TB, UD pulley, 1 7/8" long tubes, dual 3" cats, 3" Xpipe, dual 3" all the way back... and made 440rwhp/385rwtq. Compression was around 10:8:1. Redline was 7100 and routinely beat on with road racing (10+ hrs) for 20K miles with no issues.
Old 06-09-2008, 02:50 PM
98camaroLS1M6's Avatar
Nice Hp, some heads would definitely wake it up even more, congrats!
Quick Reply: Dyno sheet 233/239 92mm Ported.
