Magnuson / EATON TVS 1900/2300 Performance Maps
blownerator
1900:
2300:
These tests were preformed to SAE standards....and before you make a comment about the temperature graph....This is on a test stand withOUT an intercooler core. These are real numbers achieved in a laboratory environment. If you look at the data, you will see that the TVS is truly way beyond the 5th generation in efficiency and surpasses a screw in performance.
2300:
tvs 2300
you dont know me but im new in here . i have a 2008 tbss with the new tvs 2300 . the cost to buy this kit was 5999.99 im putting at the back tires 492rwhp 630hp at the crank at 5.5psi of boost
LS1Tech Sponsor
Looks to be pretty cool, might have to put the 2300 on the buggy and get arid of the 122. We are seeing 12-14psi depending on weather and belt slip, cammed aluminum 5.3l. IAT's run from 120-160 in the dunes, they come down to 90 after a cruise. What kind of increase would we see with the same pulley setup 3", and stock pinned crank pulley?
my bad 479wrhp 492wrhp on a good day 630 at the crank was a fig on the math maybe yalls math is better then mine the tur way to get hp at the crank is to pull the motor . by the way rpm in garner knows there stuff thanks guys
