Where do the head gaskets blow/leak/push water most of the time high hp builds
On a high hp engine build where does it start to leak at ?
Under exhaust side most of the time ?
Does the point of leaking change with a aftermarket head vs a stock one or just same spot but at a higher pressure/ hp level?
mine leaked a bit towards the headers on cylinders 3 and 4 (only in one spot per side).
made 1400 fwhp most of the year with little to no pushing until I added a few extra psi of boost and a few extra degres of timing
Guess thats what I get for getting too aggressive with my tune
Its pretty easy to see here, these are after about 100 low 9 second passes. Nothing ever leaked anywhere externally, just after a couple passes I would have to drain the overflow and put it back in the radiator when it got bad.
Those are Dart heads, the AFRs I ran afterwards were a little better but still leaked in the same place after X amount of passes.
Thank you for the pic that just what i wanted to know.
Im thinking about running just 5 bolts on my warhawk block the 4 main one then the middle one on the exhaust side. Just to see how much added hp it can clamp over just 4 bolts. 4 bolt vs 5 bolt vs 6 bolt just so i can play and learn. Yes i waste alot of time playing around with ideas.
Looks like maybe from being thinner and im guessing hotter on the exhaust port side thats where most of the leaking is coming from on the high hp builds
more to do with tune....
sbc, STD felpro 1003 gaskets ,twin hp 66's , 30 psi , NIL problems
