Wastegate Size?
Old 04-14-2009, 07:35 PM
Super Slow SS's Avatar
Default Wastegate Size?
I have a Precision 74GTS, with a .96 ar. Butt mounted, just needing to know if a 38mm will be enough or if I should go for the 44. I plan to run between 8psi now and up to 14 or so later.
Old 04-14-2009, 07:42 PM
dreamls1's Avatar
U need to go 44 for sure. I have a t76 and have a 44.
Old 04-14-2009, 07:55 PM
Yea thats what i would think, but i know a guy running a 38 on a t76 without creep.
Old 04-15-2009, 09:41 AM
LS1TECH Sponsor
DrTurbo's Avatar
We have run the Turbosmart 38's without a problem in rear mounts.
Old 04-15-2009, 11:45 AM
bboyferal's Avatar
Everyone will tell you to go bigger...
Personal experience: In my car, I've gone through a turbo, a motor, and many other things... The Turbosmart 38mm WG that came with my kit has outlasted everything else. It held 6/7 psi from the spring and 8 psi with a Turbosmart MBC (still on the car too!) with NO problems for almost two years. When I had my motor built, I adjusted the MBC, tuned it for 15 psi, and I'm still on the same WG for another two years today.
Maybe I'm lucky?
Old 04-15-2009, 11:48 AM
LS1TECH Sponsor
DrTurbo's Avatar
Maybe I'm lucky?
Turbosmart gates are top notch....we have customers still running them after almost 6-7years of abuse.
Old 04-15-2009, 01:45 PM
Silver_TransAm's Avatar
I have a 38mm gate and it has been great thus far. 30k+ miles on it.
Old 04-15-2009, 01:56 PM
What brand? and I found a good deal on a Tial 38 I think I am just going to get that.
Old 04-15-2009, 02:16 PM
Its a tial sport. authentic one.
Old 04-15-2009, 02:17 PM
Good to know, I just ordered mine, hope it works out. Guess this thread is over! Thanks to all that helped!
Quick Reply: Wastegate Size?
