408 with ls1 heads would lq9 317 head help?
Old 06-17-2009, 02:42 AM
turbotaws6's Avatar
Default 408 with ls1 heads would lq9 317 head help?
I currently have a 408 with an sts turbo with ls1 head ported pretty good. My ? is would it be worth it/help to go to 317 lq9 heads? Are the 6.0 heads better for boost? Do these flow better? I cant afford afrs. Any info would help thanks.
Old 06-17-2009, 03:18 AM
vff_jeff's Avatar
depends on the flow numbers of the ported ls1 heads. 317 have a 72cc chamber. And flow like a 243 head. good for lowering the compression which means easier to tune, and more boost can be applied.
Old 06-17-2009, 03:21 AM
MASS seller approved
smok'nZ's Avatar
it depends on how good they are ported bigger valves,5 angle cnc'd
Old 06-18-2009, 01:14 AM
turbotaws6's Avatar
The heads are supposedly ported to the max & have over $1k into total machine work and vavles. I heard the deck height wasnt high enough and the heads would lift at over 12psi? This is what I was told by a tuner. Whats the most 5.7 241s can flow on a 408 boost wise for a rearmount?
Old 06-18-2009, 07:41 AM
MaxxMitchell's Avatar
I would stick with what you have until you can sell your current heads and afford a thicker deck aftermarket head, like the AFRs.
Old 06-18-2009, 08:06 AM
MY99TAWS6's Avatar
I would wait for some afr or other thicker deck heads as well. Or look for a used set see them once in awhile.
stock 317 would be ok for cheap and would as said lower compression a bit.
Old 06-18-2009, 06:05 PM
OUTLAWZ RACING's Avatar
I run out the box patriots stg3 and the spring kit with arp studs no hint of lifting but im on a safe tune.
Old 06-18-2009, 10:52 PM
turbotaws6's Avatar
Where did you order the patriot heads from? How much are a set of those? Are using the patriot ported lq9s? Whats the part #?
Old 06-18-2009, 11:17 PM
CuNfUzEd's Avatar
Patriot heads are great. I had some on an old setup and they are good stuff. The 317 will net you a larger combustion chamber. You could run a higher boost with those heads, I would say 18 would be safe. I have a friend tha tis running 15 on 91 octane on stock 317's. 760rwhp on a 370.
Old 06-19-2009, 01:02 AM
turbotaws6's Avatar
outlawz racing what size turbo are you running? Are you a 6 speed?
Old 06-19-2009, 06:44 AM
venom ws7's Avatar
My car made 701rwhp with MTI 317 Heads very small STS Twin and small MTI Cam.
I'm thinking about going 408ci how much power are you looking for?? lots of pepole made 800+rwhp with stock heads casting.
Quick Reply: 408 with ls1 heads would lq9 317 head help?
