Big Red ATI Race valve location.
Old 08-17-2009, 08:50 PM
josepy121380's Avatar
Default Big Red ATI Race valve location.
I have the twin intercooler setup on my procharger. where is the best spot to mount this thing? any pics would be nice also. thanks in advance.
Old 08-17-2009, 08:58 PM
conan's Avatar
I have mine mounted before the coolers in the Y pipe.
http://mycarpics.shutterfly.com/235
http://mycarpics.shutterfly.com/219
http://mycarpics.shutterfly.com/262
Old 08-17-2009, 09:28 PM
badass. thats where i thought i should put it.
Old 08-18-2009, 10:16 AM
Any other ideas.
Old 08-18-2009, 10:57 AM
BIG_MIKE2005's Avatar
I'm piecing together a kit with FMIC as we speak & I'll be locating mine up top by the fuse boxes. It'll be protected from the weather & closer to the TB.
Old 08-18-2009, 12:57 PM
I dont have a FMIC. Otherwise I wouldnt of even asked the question.
Old 08-18-2009, 01:05 PM
Take a look at the set-up ran by "Trust". Seems to be workin just fine for him where it's at & it's also safe from the elements.
Old 08-18-2009, 01:20 PM
conan's Avatar
Mine is safe from the elements, I just don't drive it in the rain...
Here's some more info... https://ls1tech.com/forums/forced-in...-location.html
Old 08-18-2009, 04:19 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
When I had my dual intercoolers, mine was on the metal plenum. Worked well.
Old 08-20-2009, 09:54 AM
Isnt that going to cause heat soak?
Old 08-20-2009, 11:46 AM
ChevyChad's Avatar
its negligible. not enough to affect anything IMO i never had any problems with it there. From what I've read, its best to have it closer to the TB than further away.
Old 08-20-2009, 09:10 PM
Rickys S/C Z28's Avatar
mine is under the car and i hate it so dont do it there
Old 08-20-2009, 10:03 PM
yeah if i had a fmic setup this would be easy. only good spot is the plenum.
Old 08-20-2009, 11:02 PM
JC70SS's Avatar
I must hear that when you install Joe!
Old 08-21-2009, 07:44 AM
JAX04's Avatar
sorry to kind of hijack, but is what is the difference between a "race valve" and a wasted gate/BOV
Old 08-24-2009, 09:21 AM
Wont be til next spring now. I have decided over winter early next spring i am going to do a fmic on the car. then i can have the bypass installed the correct way in front of the intercooler.
Old 05-11-2012, 09:25 AM
I am finally looking to do this on my setup. I still have the twin coolers. However my meth is in the pipe on the passenger side of car just before the plenum. Put it there cause the guy at Alky said to. Before my IAT. Now if I put the bypass on my plenum am I going to be spraying meth everywhere when I let off the throttle?
Old 05-11-2012, 10:39 AM
NoGo's Avatar
I put mine at the first 90 after the supercharger. My thinking was I wanted it in a place and at an angle to eject as much water and gunk from the supercharger as possible.
Kinda a centripital filter....functionally, it probably doesn't make much a difference where you put it.
Old 05-11-2012, 03:39 PM
02LS1ram's Avatar
When I had the twin IC's I had it mounted the same place as chevy Chad posted in the pic above
Old 05-12-2012, 12:42 PM
I8UR4RD's Avatar
s/c make boost at all times to some degree. therefor there is pressurized air/heat that needs to be vented to the atmosphere when the TB is closed to avoid compressor surge and strain on the turbine. when the TB is opened the bypass valve closes. They are open during idle and low rpm driving.
A BOV/wastegate is closed to make boost, and when the TB closes the spring/rate that its set too causes it to open and release the excess. or at least thats how I understood it.
