cam help on 6.0 truck manifold build
Old 08-12-2010, 08:08 PM
rotacoupe95's Avatar
Default cam help on 6.0 truck manifold build
Hey guys I'm doing a lq4 turbo build I will be going with a s400-75 83mm turbo victor Jr lower with sheet metal elbow and a 78mm tb. I'm only going to be head bolts rod bolt springs and a turbo cam a buddie is selling a custom comp cam it specs are 606/610 218/228 114 wanted to no Id this would be a good cam to try its brand new and I'm getting it really cheap thats the reason I'm asking thanks for help...
Old 08-12-2010, 09:39 PM
van383's Avatar
if cheap unuf nab it... easy swap if do not like it..
Old 08-13-2010, 10:06 AM
08vetteracer's Avatar
First, what is the make/brand of that turbo? I would use a better turbo like precision or turbonetics. If that is a ebay turbo i would try and stay away from those, they are nothing but junk. As for the cam the duration is low compared to a proven turbo cam. Also what boost level and power level are you looking to reach?It sounds like your on a budget. I would do alot of research on here, there is alot of useful information.
-brad
Old 08-13-2010, 11:37 AM
00'TurboLS1's Avatar
thats a Borg warner those are very nice turbo's.
Old 08-13-2010, 12:43 PM
You get what you pay for.........They are not engineered for racing applications
Old 08-13-2010, 01:05 PM
Restricted User
98Z28CobraKiller's Avatar
But they do work. Guys running really fast with them.
OP, that cam is too small. You can go into the low 230's duration without a problem. I'd try to keep lift just under .600.
Old 08-13-2010, 01:54 PM
I no of a lot of people that run Borg warner turbo I no they not be the best but I am on some what of a budget but Its a work in progress not to say your not right but I sent Patrick g the cwm specs and he said It was a good turbo cam for taking it to 6600 or so. I want to push right about 14 pounds because of it being a 98 car.
Old 08-13-2010, 02:06 PM
ttranssam's Avatar
WHAT? 14 psi cus its a 98? did you mess that up...14 psi is a hole lot of boost for a stock 98.
Old 08-13-2010, 02:09 PM
They are inefficient and unreliable for a track car. Yea they will put down a good number but how long will it last before it blows? It seems like you your running a precision which is a quality turbo...........
Old 08-13-2010, 02:10 PM
stmz28's Avatar
98Z28CobraKiller
What size cam is in your car
Old 08-13-2010, 02:14 PM
It shouldn't matter if your building a LQ4 motor what the year of your car is. I would recommend a ball bearing turbo. And if you talked to pat they why would you need to start this thread, pat has a reputation for great cam specs. His word is all you needed.......
Old 08-13-2010, 03:33 PM
I talked to pat after I started this thread, you have your opinion on that style turbo and that cool but thats what I'm going with and threads not about the turbo its about the cam. I'm not talking about the year because motor I'm talking about the map on 98 and not being able to go over 14.7 or something like that.
Old 08-13-2010, 03:55 PM
Restricted User
It is a "good turbo cam" but what I am suggesting would be a "better turbo cam".
Originally Posted by stmz28
98Z28CobraKiller
I run the Livernois Stage 2 cam 232/232 .595/.595 on a 114 straight up. If my turbo had a T6 1.15ish backhousing, i'd run a little more split to the exhaust port. This also depends on the intake to exh flow ratio of the heads being used. As it were, I would likely benefit from swapping a reverse split cam into mine as I think the T4 .96 really isn't enough exh housing for a 370ci motor.
The boost limitation is due to the PCM in the 98 cars. You can only run a 2 bar custom operating system. 99+ allows for more boost.
That said, I pushed my 98 pcm to 20 psi. Just tune the 215 kpa line in the VE table at whatever the max boost level that you intend to run is. With a 1:1 boost ref fuel pressure regulator, the fueling stays pretty close as long as your pump(s) an injs can keep up.
Quick Reply: cam help on 6.0 truck manifold build
