what is strongest fi block
Old 10-08-2010, 07:00 PM
10.5prooutlaw's Avatar
Default what is strongest fi block
what is strongest block for fi.do we agree it is the steel lsx block
Old 10-08-2010, 07:16 PM
LS6427's Avatar
Darton ductile iron sleeved, LSX "iron" block..............
I had to....lets see who gets pissed................
Old 10-08-2010, 07:49 PM
Shawn @ VA Speed's Avatar
i don't think anybody would agree to that-atleast anybody than builds any of these.
billet block is the strongest-if made properly damn near indestructable
rhs alum is second-it does require some work in certain areas to handle high hp.
the lsx would be what i consider a distant 3rd. it will handle a good bit of power but really requires ALOT of work over 1800hp.
Old 10-08-2010, 09:37 PM
could please go into detail on work needed
Old 10-09-2010, 08:50 AM
daws222000's Avatar
Default block
what about ERL?
Old 10-09-2010, 09:27 AM
7 Second Club
Phil99vette's Avatar
Just like Shawn said....They all need work just some more than others.
1) Billet Block
2) RHS or the Warhawk are somewhat close
3) The LS2 and the LSx block both have their differences. The LSx is weak in the main area.
The LS2 and LSx are going to require a center counter weighted crank to live for a long time, pin the mains and a main support system. The RHS block is stronger in the mains but weaker in other areas. The Billet block you can have cut to order and would be the choice is money were no object.
Old 10-09-2010, 11:55 AM
1) Billet Block
the warhawk isn't close-it's a piece of junk out of the box.
Old 10-09-2010, 12:00 PM
dimetweaker's Avatar
Im not in the market, just asking for laughs, buts what a prepped billet block cost? and im mean just the block with as much work as it takes to be ready to install crank, cam, pistons etc...
Old 10-09-2010, 12:23 PM
BigRich954RR's Avatar
billets around 10K
Old 10-09-2010, 01:08 PM
bigsticksupra's Avatar
the LS2 is stronger than the standard truck iron blocks?
Old 10-17-2010, 03:46 AM
sschoeffler's Avatar
This I am interested in...
Quick Reply: what is strongest fi block
