Need Oil Pump for Maxed out D1SC
Old 11-27-2010, 05:52 PM
AFASTYZFR1's Avatar
Default Need Oil Pump for Maxed out D1SC
What is everyone running for oil pumps?
Old 11-27-2010, 07:33 PM
jjcamaro02's Avatar
running SLP hv pump
Old 11-27-2010, 08:48 PM
speedracer5532's Avatar
Melling 10296
Old 11-27-2010, 09:21 PM
bad6as's Avatar
my invoice from hke has a melling 10296 (turbo motor)
Old 11-27-2010, 10:26 PM
The Beast's Avatar
Another with the melling.
Old 11-27-2010, 11:41 PM
fatmat80's Avatar
ported ls6 from tsp on my d1sc 347
Old 11-28-2010, 01:02 AM
whitebullet7's Avatar
running slp with double roller
Old 11-28-2010, 04:31 AM
Bobsmyuncle's Avatar
melling. 60 psi @idle. pegged at WOT. love it.
i would never put anything else in a future motor
Old 11-28-2010, 10:48 AM
The Beast's Avatar
I take it you didn't put in the softer spring that came with it, like most others do lol
Old 11-28-2010, 11:24 AM
AFASTYZFR1's Avatar
Think I'm going with the Melling 10296. Does everyone run it as is, or change springs? Whatever pump that I had before had 50-60psi at idle and 80+ at wot, which is what I'm looking for I guess....or will that suck pan dry?
Old 11-28-2010, 12:00 PM
Lythropus's Avatar
I've never heard of lots of people wanting less oil pressure?
Old 11-28-2010, 12:30 PM
The Beast's Avatar
I've never heard of people wanting to take a loss of HP with minimal benefits and extra stress on the pump (especially since the OP just had an oil pump seize on him ). Seen cases of the o-rings being blown out on oil filters when pressure gets to high, and on the sbc's, the oil galley plugs being blown out. You only need enough volume/pressure to maintain an adequate oil film
The melling 96 comes with a high pressure spring and a standard pressure spring. The standard pressure spring necessarily doesn't effect volume. My oil pressure gauge "pegs out" at 150psi, THAT is to high of oil pressure.
Old 11-28-2010, 12:49 PM
Ryans99ls1's Avatar
TSP ported ls6 here. bout 50psi idle when its nice and hot, 60psi cold. WOT its always at 80psi. i think its perfect because of whats said above, i dont want things sucked dry.
Old 11-28-2010, 01:51 PM
CarsandWomen's Avatar
you need 10psi of oil pressure for every 1000 rpms your turning, so roughly 70 or 80 should be tops, and FWIW ive seen oil filters burst, as in pop and spew....
tsp ls6 ported and shimmed, turbo on a factory longblock 98 with 150k on the ticker lol
https://ls1tech.com/forums/forced-in...u-running.html
Old 11-28-2010, 02:02 PM
AFASTYZFR1's Avatar
Decided to go with TSP ported LS6....Thanks guys!
Should be back on the road in a week or two
Old 11-28-2010, 02:58 PM
fatmat80's Avatar
great choice i might be a little bias though. On a cold start it holds about 65 psi and hits almost 80 on a WOT. Good luck
Quick Reply: Need Oil Pump for Maxed out D1SC
