10.5 compression with forged pistons=good or bad? 15#
Old 12-16-2010, 08:21 AM
master blaster's Avatar
Default 10.5 compression with forged pistons=good or bad? 15#
I am thinking of buying a shortblock and was told with 317 heads and the combo below the compression should be around 10.4.
I want to run a procharger about 15#
the combo is 408
LQ4 Iron Block
Eagle Forged Crankshaft
Eagle H-Beam w/ ARP Rod Bolts
Forged Wiseco 4.030" -3cc Flat Tops
Total Seal Plasma rings
Comp Cams 54-463-11 (247/255 .624"/.624" 114 LSA)
SLP P/P Oil Pump
LS2 Timing chain set
New cam/main bearings
Balanced
if i put 317 heads can i get it to 10.4 or lower?
i want to run 13-15#boost procharger
Is this a bad idea....it seems people are running higher compression these days?
Old 12-16-2010, 08:37 AM
rotary1307cc's Avatar
FWIW i was running a static CR of 10.6 on a 370 with no IC and up to 24* of timing without any problems
E85 fuel though
Old 12-16-2010, 10:45 AM
11 Second Truck Club
sprayinLS1s's Avatar
6.0L, iron block, 10.7 comp, 10# boost, 76mm, rear mount turbo, no intercooler, snow meth, 25*, pump gas, & still got more in it.
the compression makes for instant throttle response, especially with it being rear mount, but it's as responsive as alot NA setups
i also know a guy with a GTO, 427", 10.6, F1 PC, 19# boost, pump gas, with very low timing.
Old 12-16-2010, 12:16 PM
Bullitt4110's Avatar
On my old I had a 383 at 10.9 and ran 13psi with a Vortech without issue.
Old 12-16-2010, 03:32 PM
Ryans99ls1's Avatar
itll be fine as long as there is no detonation, which is harder to keep away at higher compression levels. itll be fine though, 10.4 isnt too much at all.
Old 12-16-2010, 05:11 PM
Texas_WS6's Avatar
Make sure you run GOOD fuel in it, a meth kit would help too, and the tune is the key to doing this. I personaly wnat to go to 12 or 13:1 with 20 to 25 psi on my next build. Of course not with pump fuel.
Old 12-17-2010, 03:56 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
I agree, run methanol injection with it and you should not have any problems. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 12-17-2010, 04:24 PM
HydroStream6's Avatar
Run E85 and it would be sweeeeet. You could even get away with some 241s or 243s on there.
Quick Reply: 10.5 compression with forged pistons=good or bad? 15#
