Those who made their own alternator relocation brackets step inside
Old 03-29-2011, 05:29 PM
boost21's Avatar
Default Those who made their own alternator relocation brackets step inside
Odd question but has anyone made their own brackets using a model from solidworks and cut out on a waterjet or similar? I may be able to have a friend make me one (or a couple extras) but I need dimensions or drawings of what others have used as far as the bracket design. I would start taking measurements off my car but it is in storage 80 miles away right now.
Any help or dimensions would be sweet!
Old 03-29-2011, 06:45 PM
SScam68's Avatar
I was going to tackle this exact problem this weekend.
Not sure if I'm going to have it waterjet or have a rapid manufacturing vendor handle it.
Old 03-29-2011, 10:50 PM
Ping King's Avatar
I made one using some old headbolts, cut to length pipe, and a manual tensioner from a porsche 944. Total cost was 20 bucks.
Rock solid too.,
Old 03-29-2011, 10:56 PM
rotary1307cc's Avatar
None needed..... bolts right to the block....
Old 03-29-2011, 11:00 PM
madmax4499's Avatar
^^ sweet that is what im going to do for mine. do you have a pic of the underside.
Old 03-30-2011, 12:32 AM
boost21's Avatar
That setup posted above looks great but the setup I have is for forward facing headers so the alternator needs to be mounted high. I have looked at a few setups and have some ideas in mind but will need to make some drawings first and see what options are out there. Biggest thing I don't want is flex in the bracket since I have heard of some throwing belts because of it.
Old 03-30-2011, 06:25 AM
Nitroused383's Avatar
Pretty much just built my own on the cnc here is the thread with dimensions in it https://ls1tech.com/forums/forced-in...ount-pics.html
Old 03-30-2011, 11:09 AM
boost21's Avatar
The drawing in your thread is exactly what I was looking for. Going to see if I can replicate it for my car. Thanks!
Old 03-30-2011, 11:51 AM
madmax4499's Avatar
looks great, im trying to figure out a way to run just the water pump and alt. i want my alternator low to keep the engine bay un-cluttered as possible. does the alternator care what direction it spins? assuming it was new.
Old 03-30-2011, 12:33 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Originally Posted by madmax4499
...does the alternator care what direction it spins? assuming it was new.
You planning on turning the alternator around to where the pulley faces the rear of the car?
Old 03-30-2011, 02:48 PM
Tally TransAm's Avatar
i made mine outta the stock bracket
Old 03-30-2011, 05:42 PM
Broke EF's Avatar
www.aeicnc.com He makes a aluminum bracket that mounts low and clears the truck manifolds. Here are some pics of it on our car.
It comes with the upper bracket, lower bracket, the turnbuckle with heim joints, stainless brace, aluminum pulley, and all necessary hardware. I think he can supply the alternator as well. Talk to Bob, tell him Sean sent ya!
Sean
Old 03-31-2011, 01:01 PM
Ryans99ls1's Avatar
^^^ would be great if i wasnt running my downpipe there.
Old 04-01-2011, 05:01 AM
fastsspr's Avatar
But how you did it ?
Old 04-01-2011, 08:37 AM
Loudmouth LS1's Avatar
Yeah, i'd like to know that as well.
Old 04-01-2011, 09:14 PM
stock bracket
modded bracket
installed.
sits nice and low which i like
bolts to the outer most threaded hole in the pass side head using a spacer for proper belt alignment and uses a small slide tensioner mounted between the alt and the hole on the water pump for the stock tensioner
couple notes, the belt runs right across where the head of one of the bolts goes so you have to grind the head down some. and i dont have a stock alternator on my car, the one i have has a different plastic back but im pretty sure you could mod the back of the stock fbody alternator. you also have to take a minor amount of material off the alternator where it bolts to the slide for alignment
Old 04-01-2011, 10:58 PM
TX RED's Avatar
I'm going to try this next week... thanks tally
Old 04-02-2011, 12:01 AM
tripblackls1's Avatar
i did that as well but now i need another stock alt bracket for belt clearance
Quick Reply: Those who made their own alternator relocation brackets step inside
