408 twin turbo - which cathedral head?
Old 06-08-2011, 07:15 PM
TracyRR's Avatar
Default 408 twin turbo - which cathedral head?
Looks like i will step up to some thick deck heads and i'm looking at a few right now but need some direction please...which brand and what size runner? Here is the combo: 408" iron truck block, pinned mains, pyramid head gaskets (andreas), twin precision 6765's, 238/243 604/612 at 115, 9.0 comp, ls6 intake and th400. More info in sig if needed.... Not looking to break the bank but want a good head that can help me max out these turbo's and maybe go larger turbo later. Also, not overly concerned with low end torque because this is a street car with limited traction down low anyway. Thanks for any help! tracy
Old 06-08-2011, 07:44 PM
OUTLAWZ RACING's Avatar
trickflow 235 alittle to much head but worth it.
Old 06-08-2011, 09:46 PM
blk00ss's Avatar
Just curious, but why do you think that's to much head?
Old 06-09-2011, 07:55 AM
bluehawk2's Avatar
http://www.mastmotorsports.com/2010/...sembled&id=369
those are some really nice heads. They are six bolt for future growth and your turbos wont care if they have a 225 235 or 245 intake runner.
Old 06-09-2011, 08:18 AM
TracyRR's Avatar
Thanks outlaw!
Killer heads but it looks like i would have to change my shaft rockers and intake manifold. Correct me if i'm wrong. I might look into the ls3 intake/rockers just to give me an idea on price. thanks
Old 06-09-2011, 10:50 AM
El_Diablo's Avatar
My TFS 245s. /thread. haha 245 isn't too much intake runner...boost.
Old 06-09-2011, 04:30 PM
bluehawk2's Avatar
they are still cathedral port heads, but yes they require the ls3 style rockers which mast has available or you can use stock. Im not saying the other heads wont do the job, but the mast/ PI/lxr/etp heads would be my number one choice.
Old 06-09-2011, 04:52 PM
TracyRR's Avatar
If my intake would fit, that would be a huge plus for that head.... rockers are not that pricey. Thanks blue
Old 06-10-2011, 02:13 AM
venom ws7's Avatar
The new AFR 230 look awesome call Tony mamo..
Old 06-10-2011, 04:39 AM
Nitroused383's Avatar
Trickflow 220 as cast heads for a budget thick deck head with decent flow. Have Brian Tooley do a little hand blend bowl work for a few bucks extra.
Old 06-10-2011, 06:14 AM
Boosted One's Avatar
It all depends on your budget. I wouldn't go ape **** with heads. With your setup you could put 317s on and still make more power than you can use. I'm running as cast Darts and have never complained of not having enough power. I have less than $1500 wrapped up in my heads including the combustion chamber work. -- just another budget friendly option.
Old 06-10-2011, 08:26 AM
TracyRR's Avatar
hey sam, the afr 230 is def on the short list!
Hey nit, as usual, time is not on my side so i would prob use something out of the box.
hey frank, that is cheap! Unless i find a nearly new set of heads (used) that have already been tricked out, i'm just going to slap a thick deck set on the new motor. Thanks guys!
Old 06-14-2011, 05:26 PM
jonathan8751's Avatar
My vote goes for the prc 237 heads. Thats the head I went with on my 408 front mount build.
Old 06-14-2011, 07:39 PM
7 Second Club
Phil99vette's Avatar
trick flow 220s and spend the rest on an intake.
Old 06-14-2011, 09:17 PM
TracyRR's Avatar
Thanks guys! I'll prob just do what phil is saying.... Keep it simple and just turn up the boost a little more. The patriot's i have flow pretty well, i just need a thick deck to keep it together.
On a side note, i just received my Cooper Ring head gaskets from andreas in sweden. Not cheap for a head gasket but if it holds the boost, it's worth twice that amount.
Old 06-15-2011, 01:08 AM
kmracer's Avatar
mozez.
but srsly, K.I.S.S.... just go with something basic thats been proven.
Old 06-15-2011, 01:15 AM
Fbodyjunkie06's Avatar
TFS as cast simple as it gets.
Old 06-15-2011, 01:34 AM
westtexasbuff's Avatar
LSAs or L92s, ask me why
http://www.youtube.com/watch?v=bjWwHPHxfi0
Old 06-15-2011, 08:35 AM
TracyRR's Avatar
Originally Posted by kmracer
mozez.
ha ha.... good one!
keep it simple stupid!
wtf, i was not expecting that!! that is a bad m'f
Old 06-15-2011, 08:40 AM
Mr.427's Avatar
You may also want to consider World heads. They have six bolt heads for the high boost cars.
Quick Reply: 408 twin turbo - which cathedral head?
