No lift shift
Old 02-09-2012, 10:05 PM
maxgee's Avatar
Default No lift shift
Anyone have experience with this product?
Old 02-10-2012, 12:21 PM
pwrtrip75's Avatar
I have a couple friends that ran something like this on DSM's.. I dont think they had a fancy box like this though?... All you need is a 2-step and a switch on your clutch pedal.
Old 02-10-2012, 08:41 PM
My2kz28's Avatar
Hmmm Is that really easier on the trans?
Old 02-11-2012, 07:17 AM
427's Avatar
That type of shifting is really better when using a dog style trans, it will be better for the trans/clutch than full throttle shifting with the clutch. If you are running LS power and face tooth/dog trans you should look at Lingenfelter box with strain sensor in the shifter arm, very well thought out product for these cars.
Kurt
Old 02-11-2012, 08:14 AM
My2kz28's Avatar
Makes sense..ive got a stock t56 with 650 rwhp..am i better off just shifting regularly or would a lingenfelter box and no lift shift be too much for a stock t56?
Old 02-11-2012, 09:01 AM
427's Avatar
With a factory trans I would just shift normally.
Kurt
Old 11-04-2014, 11:36 PM
Ashley7745's Avatar
Default no lift shift
What website can i access for the no lift shift 200$? I need to order one. ..
Old 11-05-2014, 07:58 AM
Restricted User
JoeNova's Avatar
The first time I ever ripped all of the teeth off of 4th gear was from flat-shifting.
I was using a switch under the clutch pedal to kill spark. Pushed the clutch in, pulled it down into fourth, and the trans let go as soon as I let the clutch out. There is a pretty good amount of 'shock' when you use spark cut as well. All of the unburned fuel ignites in your hotside when you let the clutch back out.
Old 11-05-2014, 07:59 AM
cptinjak's Avatar
You can shift any t56 car "no lift". Just do it fast. My right foot doesn't move when I shift my bone stock t56 with the stock c5 shifter.
Jack
Old 11-05-2014, 08:19 AM
LS1Tech Sponsor
hellbents10's Avatar
I agree with Jack just practice, I can no lift shift a T56 car no problem.
Old 12-02-2014, 09:45 PM
Ashley7745's Avatar
Where can I order a no lift shift?
Quick Reply: No lift shift
