347 turbo batmowheel
Old 11-19-2012, 01:06 PM
mrada6998's Avatar
Default 347 turbo batmowheel
so im building a forged 347 and am picking out a turbo. im trying to make a super fast street car an go 9's. i need to figure out what turbo to go with. i want around a 72mm or somewhere around there.
just wondering, has anyone used the bulleye's batmowheel turbo? they look like a killer design and they make some big claims on their website, but is it worth the money?
tahnks
Old 11-19-2012, 01:09 PM
Sales@Tick's Avatar
Check this out, it may influence your decision.....
Old 11-19-2012, 01:11 PM
Brad Campbell's Avatar
I'm using a 75mm Batmowheel turbo.... I think you would be the second person to do this from what I have seen.
https://ls1tech.com/forums/forced-in...o-project.html
https://ls1tech.com/forums/dynamomet...atmowheel.html
Old 11-19-2012, 01:24 PM
mrada6998's Avatar
what does that chart mean? i mean, can u help me intemperate it.
and whats your experience with it so far man? good decision? good spool and power?
Old 11-19-2012, 01:32 PM
I couldn't be more happy. Spools hard, and keeps pulling. I'm making 700ftlbs at the tires before 3500 rpm. I paid extra to have a turbo that would have a lower boost threshold, but still make excellent numbers. I think that goal was attained.
Old 11-19-2012, 01:44 PM
The Borg has a little better efficiency, and more flow out the back end where you would be in kill mode.
Martin, do you have that same plot for a 75mm comparison?
Old 11-19-2012, 03:10 PM
Sales@Tick's Avatar
I sure don't Brad I wish I did, I might see what I can round up though.
Basically in very simple terms, that chart is showing that the S480 has a higher and wider efficiency island the harder you push it. When it's not being pushed too hard they are close to the same, but as you turn the wick up more and more the S480 compressor wheel will start to shine.
Old 11-20-2012, 12:15 AM
BAKED's Avatar
Im running an 80 mm. W/ batmo wheel on my 347 and Im pretty happy with the results. A few weeks ago we turned it up to 25 psi and made 1063 rwhp through a glide and 9". Im running ported 853's, custom cam, a2w, on e85.
The car went 8.92 @ 159 on 16.5 psi at 3430 raceweight.
Old 11-20-2012, 12:44 PM
Sales@Tick's Avatar
Shum your car is VERY impressive!
Old 11-20-2012, 01:09 PM
killernoodle's Avatar
I think the chart shows that the batmo wheel has nearly the same efficiency as the cast borg warner wheel (though it looks like the cast wheel is actually better in most areas), and if they are the same mass they should spool the same too. What do you benefit from going with the way more expensive wheel at that point?
Old 11-20-2012, 01:18 PM
Rickys S/C Z28's Avatar
I was going to post up about Shums car but he beat me to it lol . Killer turbo You cant go wrong with it
Old 11-20-2012, 04:21 PM
Sales@Tick's Avatar
That would be a good question for Dr. Turbo to answer.
Old 11-20-2012, 05:29 PM
T76s10's Avatar
That's what i have heard to.
Old 11-20-2012, 05:48 PM
Yep, just found an article about this. Apparently the regular cast wheel outperforms the batmowheel in nearly every respect, especially price.
Why are these things around then? For the blingy ricer crowd?
Old 11-20-2012, 07:09 PM
burbalanche's Avatar
so is there really no point for the billet wheel on any turbo then?is it really worth the money?
Old 11-20-2012, 07:19 PM
T76s10's Avatar
No. Save that money for a race cover
Old 11-20-2012, 09:18 PM
I have had 3 turbos and non if them have work as well as baked turbo .
Old 11-21-2012, 07:16 AM
SS4Matt's Avatar
I'm running a cast wheel 80mm bullseye turbo with their race cover. It makes good power and goes 9's on pump gas and 10# not really trying...
There are quiet a few Batmo and other bullseye turbo cars in my neck of the woods and they seem to perform pretty damn good when they're set on kill
Old 11-26-2012, 04:25 PM
mrada6998's Avatar
well bit the bullet and ordered a botmowheel 72mm. should be here thursday.
then just build the rest of the car and ill let you guys know how it is. lol
Quick Reply: 347 turbo batmowheel
