what cr are u high hp e85 turbo street car guys running?
Old 02-13-2013, 04:48 PM
TermnEatr's Avatar
Default what cr are u high hp e85 turbo street car guys running?
Is 10.1 too high?
Old 02-13-2013, 05:04 PM
ws602's Avatar
10.1 solid roller LME built LSX 427 built for twins 76 mm turbos. It made big power on the engine alone so i cant wait to pour the boost to it...
Old 02-13-2013, 05:16 PM
mpatton's Avatar
Not totally sure yet but I think my cr will be higher than that and the builder/ tuner says won't be an issue on e85.
Old 02-13-2013, 05:21 PM
MWatson17's Avatar
I think I remember reading a thread on here about this. If I remember right, the consensus was with E85, the sky is pretty much the limit. Some guys were running 12:1. Most of these cars were around 900+whp.
Old 02-13-2013, 05:54 PM
Wicked69's Avatar
I don't think they are running 12.1 with E85. At least not the majority. I would think anything in the 10 range would be fine, even low 11's.
You should be fine. Next year I plan to put the pistons out of a 4.8 in my 5.3 and that should give me around 11.5 to 1. I am willing to try it and tune for it so my car will have more power out of boost but that may be pushing the CR a little.
Old 02-13-2013, 07:31 PM
TermnEatr's Avatar
Awesome thanks!
Old 02-13-2013, 08:53 PM
dschmittie1's Avatar
I an 10:1 on E85
Old 02-13-2013, 10:08 PM
evo462's Avatar
Isn't 10.1:1 the stock LS1 compression ratio? I'm sure there's plenty of F/I people running that on E85
Old 02-13-2013, 10:40 PM
I8UR4RD's Avatar
I am running around 9:3-9:5 ish. (different calculators come up with different answers)
Reason being my car sees time on the street and E85 is not available everywhere. I will have dual tunes. I will be running 93 on trips and put the e85 in on race nights.
Old 02-13-2013, 10:45 PM
Ryans99ls1's Avatar
ran 10.1 on my stock bottom. E85 is what kept it alive and made it run it hard!
Old 02-14-2013, 02:11 AM
BAKED's Avatar
11.5:1 on my 347. Made 1063rwhp through an auto on 25psi
I love me some e85
Old 02-14-2013, 04:08 PM
chrs1313's Avatar
I love me some e85
What heads and intake?
Twins or a single?
Old 02-14-2013, 04:28 PM
Restricted User
98Z28CobraKiller's Avatar
IMO, for us 4 bolt heads guys atleast, I think it's easier to keep the heads on with boost generated cylinder pressure vs compression generated. I think spreading it over the larger area helps. But I will say that I have no data to prove this.
Old 02-14-2013, 06:27 PM
runsfromdacops's Avatar
im on 10.8 to one on gas and doing just fine. e85 should be good up into the 12s if you have a good tuner
Old 02-14-2013, 07:12 PM
scooter k's Avatar
9.5:1 408@21psi. Made 977rwhp in truck on E85
Old 02-15-2013, 06:40 AM
ittwgn's Avatar
same 9.5 to 1, 408ci, 1004rwhp @ 24psi thru t400 auto on pump e85 !!!!
Old 02-15-2013, 09:34 PM
7 Second Club
NicD's Avatar
I would agree with you.
Old 02-16-2013, 09:57 AM
MWatson17's Avatar
Definitely not the majority, but they are out there. Most are more track oriented than street though.
Quick Reply: what cr are u high hp e85 turbo street car guys running?
